James' 1997 RZ VVTi T88-34D Single Turbo - Respray and new CCWs [pg 32]
James
So weird that your rear plate flew off as well!?
I've got my replacement but has anyone got any suggestions/links to a strong adhesive tape!?
Cars looking great buddy!:thumbs:
This is the strong adhesive tape I'm going to use this time:
http://washford.scene7.com/is/image/Washford/698563?$PDP_MAIN$
:lol:
I'll just buy more as and when :thumbs:
I'd rather that than having to continually replace a disappearing plate haha!
The other option, of course, being to finally paint and fit the UK spec rear. But then I'll have to drill for the diffuser again. Urgh. :)
how are you fitting your private plates ??
you need to buy proper number plate stickies then fill centre section up so level then fill the full bar with 4 stickies across..
(then you will be fine)
That is what I did...I put mine down to the freakishly hot Aberdeen weather that day.
The original plate from when I picked the car up was just held on with a pad (well, a couple built up to extrude enough) each side. The passenger side was less sticky than the driver side, causing the plate to sag down and rest on the recess slightly. I then built it up again with new pads when I changed it, but to no avail.
It'll be easier just bolting. :)
  • 2 weeks later...
  • 2 weeks later...
Next thing that I am on the lookout for is a set of winter wheels, even if just to stand the car on if I choose not to use it over the next while, as I want to get the CCWs inside and clean them up nicely and sealed in prep for next year. :)
I might also be keeping an eye out for cams and there may be a slight chance that I will get the boost controller set up for higher boost and have the map checked out to make sure it is all good for that... :D
Or you could just swap your ccw's for my xxr's and not worry! Haha! :innocent:
In all seriousness I love this car and more boost can only make it better! :D
You not going to be using the car over winter?
You could lend me your XXRs over winter yep, but the CCWs will be staying with me too ;) :D
I will probably use it for a little while but when the bad weather starts properly setting in then I'll be parked up and keeping it pretty instead. :) I don't have a daily though, so a bus pass may be the best bet :lol:
Haha damn! Worth a try! :p
Yep I put mine away yesterday because I would hardly be using it in the next little while anyway. Bit of a shame though! Oh and I am now on a bus and can confirm - it sucks! Haha! :D
Next thing up for consideration is whether to pounce on one of the carbon windscreen scuttle panels from Whifbitz. I don't want to go over the top with the carbon on the exterior of the car, but I see special offer prices and think that it'd be a wise idea (they look great too anyway, and I don't have that much carbon on there - just the lip and diffuser! :D ).
It looks good against the black too:
I also need winter wheels soon. It is getting chilly and cleaning the CCWs takes long enough when I'm enthusiastic about it nevermind when I'm freezing haha!
http://www.garagewhifbitz.co.uk/news/wp-content/uploads/2013/10/whifbitzcarbonsuprawindscreenpanel.jpg
Bite the bullet mate, at those prices you are not about to loose out if you decide its not for you after all :thumbs:, Although i suspect you will love it!!!!
I'm saying it like I've not already made up my mind haha! I just need to get on with it and actually purchase it! Just a shame, all of the Scottish Supras are going to be adorning the same aftermarket parts haha!
As a side note, the car will be getting another nice little run to Glasgow and back on Saturday. Hopefully the weather stays on my side for letting me stretch its legs. :)
