Tensioner
Guest dlwarrior
Guest dlwarrior
Hi all
Just a quick question got a rattle on tick over . Pritty sure its the tensioner in middle of front engine (auxillary belt tensioner) is this a diy job and how easy is it to do.
Any ideas where best place to purchase. JZA80 N/A model
Many Thanks
Guest dlwarrior
many thanks looked at your links but to be honest they both look the same. What would you need to confirm which part is required
Thanks
Does the crank pulley have to be removed to take the lower cover off?
Yes, but I don't think you need to take lower off to change the tensioner. Just upper. Im pretty sure its just three bolts. holding it on.
