question about replacing bootlid.
liam1
just did a search and read a post on replacing bootlid one of the replies mentions getting to the wiring down the side of the inner quarter panel,i have a bootbuild in my car and have no way of getting to the inside of the rear quarter panel,can i change the bootlid and wire it back up without getting to the quarter panel.
only replacing it due to a rust spot getting a second hand bootlid was cheaper than a qoute to repair damage.
theres a sort of rubber grommet sock on the loom then it goes into the quarter panel,on the car they do fit i had to wriggle them in and out when i wanted to change my boot lid to carbon
What was the fit of the carbon boot like? Where from? Sorry Kaan! :D
What connector did you push through the boot lid the loom connector or the wiper/light connectors?
Its ok mate, not my thread ;)
Edited by Kaan W (see edit history)
wiper and brake light connector mate through the top hole the connector for the inside of the quarter panel can pull out through enough to connect or disconnect the plug and pop it back inside the quarter panel...
was a vis bootlid , bignum has it i think yeah it was pretty not the best fit but perfect for a curcuit car it was on SteveL time attack car bootlid..
The connections are in the bootlid, remove all the clips near the wiper motor well that part of the boot and pull the slack up at the top of the boot where the gromit is and unplug it there then fit new boot and plug in it should be very simple
looking at the replacement bootlid this seems about right mellonman, depending on the weather im going to replace bootlid this weekend.
thanks for all the input and replies.
