Rob_Mitchell Posted May 13, 2013 Share Posted May 13, 2013 Hey guys just a quick question, the supra we bought as the donor car has a 5 speed manual box fitted, now would this be ok to use for the v8 conversion?? we know the other route is to put a auto box on, change transmission tunnels ect but just curious if we can use the 5 speed box. Any help is much appreciated Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 13, 2013 Share Posted May 13, 2013 You can use both - Paul Whiffin uses the autobox on his 1UZ-FE V8. If you ever want more power you would either have to go builtbox or go manual. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 13, 2013 Author Share Posted May 13, 2013 You can use both - Paul Whiffin uses the autobox on his 1UZ-FE V8. If you ever want more power you would either have to go builtbox or go manual. So how do you go about using a manual box mate? as all the 1uz-fe engine marry up to an auto. We wont be going mad with the power on this build. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 13, 2013 Share Posted May 13, 2013 So how do you go about using a manual box mate? as all the 1uz-fe engine marry up to an auto. We wont be going mad with the power on this build. I dont know mate, Drop Paul Whiffin a PM as he's not long finished the V8 build. Quote Link to comment Share on other sites More sharing options...
Style Posted May 13, 2013 Share Posted May 13, 2013 Companies and I think even Paul can make up adapter plates that will allow the manual to work on the 1UZ. I did a bit of research as a possibility on my NA 6 spd EDIT: Something like this http://www.1uzfeswapkit.com/W55565758-manual-transmission-to-xUZFE-adaptor-plate-0000-0012.htm Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 13, 2013 Share Posted May 13, 2013 http://www.quantum-auto.com/adapters.html Many more online Rob Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 13, 2013 Author Share Posted May 13, 2013 Ok thanks guys, would be a better way if we kept the 5 speed box. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 13, 2013 Author Share Posted May 13, 2013 http://www.quantum-auto.com/adapters.html Many more online Rob Thanks ill have a browse... would have prefered a uk based company though Quote Link to comment Share on other sites More sharing options...
Style Posted May 13, 2013 Share Posted May 13, 2013 I think I saw someone post drawings of all the components online somewhere. Might be wrong, maybe a Soarer club or something which could allow you to knock them up yourself? Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 13, 2013 Share Posted May 13, 2013 Join up on Lextreme, plenty of info on there. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 13, 2013 Author Share Posted May 13, 2013 Ok thanks Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 13, 2013 Share Posted May 13, 2013 My google skillz are weaksauce but I turned up this.. http://www.v-eight.com/tech_forum/viewtopic.php?t=753 Would imagine a machine shop would knock that up relatively quickly as its just a plate. Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 13, 2013 Share Posted May 13, 2013 The v-eight.com website was a source of really good techy info for me when I did my build. Lots of very helpful guys with actual experience of doing this conversion and actual technical/engineering drawings that a machinist could follow in order to replicate an adapter plate for the V8. Not sure if its still running as it was badly hacked a while ago, so I stopped using it. Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 13, 2013 Share Posted May 13, 2013 The v-eight.com website was a source of really good techy info for me when I did my build. Lots of very helpful guys with actual experience of doing this conversion and actual technical/engineering drawings that a machinist could follow in order to replicate an adapter plate for the V8. Not sure if its still running as it was badly hacked a while ago, so I stopped using it. Just logged in and it seems fine now, with new posts and up to date replies. Quote Link to comment Share on other sites More sharing options...
