Afr gauge signal wire help
T14PPA
Innovate has my vote also, two analogue outputs which are programmable very easily to output a wideband 0-5v or a narrowband simulator. You can also set the linearisation for the 0-5v output in the software. Also has an easy calibration with a pushbutton. All of the above helps a lot if your trying to feed an input on an aftermarket ecu.
Ill probably buy that one. Where does oil temp gauges go
You will need a gauge with a sender to see oil temps, there is no oil temp as std, sounds like you have an N/A?
in which case unless your going N/AT then your notlikelyy to need an AFR gauge, the N/A stays in closed loop until WOT.
Sorry thought you had an N/A, if you have a single turbo fitted then yes definitely fit a decent wide-band, what ECU are you using?
No problem. I bought a hks fcon gold off ryan g and im waiting for him to map and fit it. Ok ill buy a wideband. Just aint sure how ill do oil temperature
