TubbyTwo Posted May 11, 2013 Share Posted May 11, 2013 Hi folks Need to know the size and number of the bolts that hold to crash bar to the front. Out and about and want to pick some up so cant check the car. Thanks Si Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 12, 2013 Author Share Posted May 12, 2013 Anyone know? Quote Link to comment Share on other sites More sharing options...
supra joe Posted June 8, 2017 Share Posted June 8, 2017 Anyone know the bolt part numbers or have a diagram? Of the crash bar with part numbers. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 8, 2017 Share Posted June 8, 2017 (edited) I'd have thought they'd be either M8 or M10 and around 30mm long under the head https://www.megazip.net/zapchasti-dlya-avtomobilej/toyota/supra-1937/jza80-3746/jza80-alpqz-426349/front-bumper-bumper-stay-5535683 http://www.toyodiy.com/parts/p_J_1995_TOYOTA_SUPRA_JZA80-ALPQZ_5201.html 90119 - 06388 x 6 Edited June 8, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
supra joe Posted June 8, 2017 Share Posted June 8, 2017 Brilliant thanks Dunk. Quote Link to comment Share on other sites More sharing options...
evinX Posted June 8, 2017 Share Posted June 8, 2017 I have strong reason to believe they are M6, i remember when i was fitting mine, the holes had closed up and had to run a M6 tap into the holes. Need 6 bolts - 90119-06388 Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 8, 2017 Share Posted June 8, 2017 (edited) You could very well be correct with them being M6 It would appear 90119 06338 has been replaced with 90119 06492 as in evinx's photo Edited June 8, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
evinX Posted June 8, 2017 Share Posted June 8, 2017 You could very well be correct with them being M6 It would appear 90119 06338 has been replaced with 90119 06492 as in evinx's photo Yep alot of bolts have crossed over to new numbers. Happens alot Quote Link to comment Share on other sites More sharing options...
