jake supra Posted May 11, 2013 Share Posted May 11, 2013 Need some advice. Seen this on the Whifbitz site. Will this work for a new fuel line from the fuel filter to engine, replacing the stock fuel pipe?? http://www.garagewhifbitz.co.uk/index.php/garage-whifbitz-15378.html Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted May 11, 2013 Share Posted May 11, 2013 I think it would but you're best popping them a message at [email protected] and asking. Very helpful guys Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 11, 2013 Share Posted May 11, 2013 It's just some Earls/Goodridge/Aeroquip type connectors and braided fuel hose. It's probably the wrong fittings and length for what you want, but you can make up anything you want from individual parts. They aren't cheap but they are good quality. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 12, 2013 Share Posted May 12, 2013 Need some advice. Seen this on the Whifbitz site. Will this work for a new fuel line from the fuel filter to engine, replacing the stock fuel pipe?? http://www.garagewhifbitz.co.uk/index.php/garage-whifbitz-15378.html Yes this replaces the pipe between the fuel filter and fuel rail. Quote Link to comment Share on other sites More sharing options...
jake supra Posted May 12, 2013 Author Share Posted May 12, 2013 Yes this replaces the pipe between the fuel filter and fuel rail. Thanks Paul. Is it just for 2JZ? I need it for my 1JZ conversion do you know if they use the same fuel rail on the 1JZ? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 13, 2013 Share Posted May 13, 2013 Thanks Paul. Is it just for 2JZ? I need it for my 1JZ conversion do you know if they use the same fuel rail on the 1JZ? I don't know if it will fit a 1JZ, sorry Jake. Quote Link to comment Share on other sites More sharing options...
