AEM software showing rich Uego showing lean
Kev.O
  • Replies 58
Yes you need to change the MIN voltage.increase the voltage by about 0.5volts and that should see a increase in throttle position. you can play around with the voltage to see how car idles anything from 1-1.5% throttle should be fine. It makes a huge difference on how smooth the car idles and performs when lifting off throttle whilst driving
  • 2 weeks later...
Setting the minimum voltage for TPS is as follows
Go to SETUP - SENSORS - THROTTLE POSTION SENSOR- OPTION TPS- and set minimum voltage from 0.00v to approx. 0.33v that should give you a about 1-1.5% on closed throttle position
you can send me screen shots on whatsapp 07834 338861:)
