Monkpower Posted May 8, 2013 Share Posted May 8, 2013 I clearly don't get on with crank pulleys... My first experience was 2011 when the inner part came off, fair enough I got a new one fitted. A non genuine part, lasted about 6months before in came apart. Hmm yes I know lesson learned. Got it replaced with a genuine Toyota part. Happy days, right? Well, today whilst driving down the A2...BANG, SMASH, SMASH, SMASH... I was able to limp it to my work car park, with no power steering and the temperature rapidly rising. Bonnet goes up lets have a look. Back of the crank pulley completely came apart, sending broken pieces furiously flying around the engine bay. The alternator was broken clean off its mounts, tensioner destroyed including the arm. Only thing intact was the actual fan belt. For some reason I cannot post photos at the moment. What do you think could be causing so many crank pulley failures? - - - Updated - - - Apologies maybe I should have posted this in the technical section. Quote Link to comment Share on other sites More sharing options...
DaveR Posted May 8, 2013 Share Posted May 8, 2013 Ouch. Not good news matey, gutted for you. Maybe it's time to invest in a welded crank pulley? Quote Link to comment Share on other sites More sharing options...
David P Posted May 8, 2013 Share Posted May 8, 2013 When the first one went it probably caused further unnoticed damage which has caused further failure. Quote Link to comment Share on other sites More sharing options...
Monkpower Posted May 8, 2013 Author Share Posted May 8, 2013 Yes this is a possibility. Getting it looked at so we'll see what the score is. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 8, 2013 Share Posted May 8, 2013 If the one you fitted wasnt brand new, theres your problem. But its pretty bad luck to have 3 go. Quote Link to comment Share on other sites More sharing options...
Monkpower Posted May 8, 2013 Author Share Posted May 8, 2013 Always fitted new ones. Quote Link to comment Share on other sites More sharing options...
Abz Posted May 8, 2013 Share Posted May 8, 2013 The answer to this is to either put a V8 or TT engine Quote Link to comment Share on other sites More sharing options...
clay Posted May 8, 2013 Share Posted May 8, 2013 The answer to this is to either put a V8 or TT engine WHAT HE SAID. mate that's not good. hope you get it sorted. ASAP Quote Link to comment Share on other sites More sharing options...
listy Posted May 8, 2013 Share Posted May 8, 2013 Could a damaged crank cause this to repeatedly happen? Quote Link to comment Share on other sites More sharing options...
Monkpower Posted May 8, 2013 Author Share Posted May 8, 2013 Its all giving me a headache. Not sure if its going to be worth throwing money at it that I don't really have. Quote Link to comment Share on other sites More sharing options...
trebor69 Posted May 8, 2013 Share Posted May 8, 2013 (edited) Only thing that springs to mind is excess stresses on the pulley .....belt having to work harder pulling other pulleys round .....are all of your other ancilliaries turning freely .....alternator/power steering/tensioner/aircon etc .......they should last way longer than yours seem to be doing One other thing causing the rubber bonding to fail is excessive temperatures heat or cold ??? Edited May 8, 2013 by trebor69 (see edit history) Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 9, 2013 Share Posted May 9, 2013 very odd to have them go like that, i feel sorry for you mate Quote Link to comment Share on other sites More sharing options...
jimojameso Posted May 9, 2013 Share Posted May 9, 2013 Sorry dude hope you get it sorted Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 9, 2013 Share Posted May 9, 2013 If it was a brand new, genuine pulley from Toyota Id be contacting them and asking some questions. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 9, 2013 Share Posted May 9, 2013 Check the alternator mounting tab on the bottom of the block. (Bottom altenator mounting hole) I hate to say it, but this is more likely to have snapped than the alternator itself. Not that that's the problem, but it's worth checking before deciding on future direction. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 9, 2013 Share Posted May 9, 2013 Check the alternator mounting tab on the bottom of the block. (Bottom altenator mounting hole) I hate to say it, but this is more likely to have snapped than the alternator itself. Not that that's the problem, but it's worth checking before deciding on future direction. Thats exactly whats broken off too James, i have the car with me. It needs a new/second hand engine fitted, never seen this much damage before caused by a crank pulley failure. The idler itself is snapped cleanly in half too! god knows where the rest is. Its has ripped the alternator straight off its mounts. Its going to be costly thats for sure. Definately a hard decision to make. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 9, 2013 Share Posted May 9, 2013 slutters had a N/A engine for £50 so could be cheapish Quote Link to comment Share on other sites More sharing options...
clay Posted May 9, 2013 Share Posted May 9, 2013 Ther was a na engine on hear last week for £50 ill try and find the add Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 9, 2013 Share Posted May 9, 2013 On a side note, crank pulleys are service items like cam belts and auto box filters. If they were changed at the correct intervals things like this could be avoided. Quote Link to comment Share on other sites More sharing options...
clay Posted May 9, 2013 Share Posted May 9, 2013 Thats the one i was thinking of. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 9, 2013 Share Posted May 9, 2013 On a side note, crank pulleys are service items like cam belts and auto box filters. If they were changed at the correct intervals things like this could be avoided. but that was his 2nd since 2011 Quote Link to comment Share on other sites More sharing options...
clay Posted May 9, 2013 Share Posted May 9, 2013 Im shore he said its the forth one in two years. Quote Link to comment Share on other sites More sharing options...
Justin Bieber Posted May 9, 2013 Share Posted May 9, 2013 Sorry to here about this mate! If i can help at all let me know Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 9, 2013 Share Posted May 9, 2013 On a side note, crank pulleys are service items like cam belts and auto box filters. If they were changed at the correct intervals things like this could be avoided. Its his third pulley!! just bad luck as i cant imagine he had them fitted wrong Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 9, 2013 Share Posted May 9, 2013 dont think you can even fit them wrong they have a woodruff key and 1 bolt! my second one is about 4 years old and looks as good and new still Quote Link to comment Share on other sites More sharing options...
