Guest Lyall Posted May 7, 2013 Share Posted May 7, 2013 Took the car to the garage and they have said someone will need to open it up and look at it as they wont touch it. Does anybody know of anyone in or around glasgow that specializes in this kind of thing? How much do you reckon I will be out money wise with new trans and labour? Has anyone had the same problem with thier sup? Any help would be great. Cheers Lyall Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 7, 2013 Share Posted May 7, 2013 Whats up with it? I wouldnt bother getting the gearbox looked at, get a replacement from keron on here for a few hundred quid and fit that. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 7, 2013 Share Posted May 7, 2013 As mentioned in your other thread a good second hand transmission will be around the £300 mark, not to forget that if you have debris in your transmission then you have more than likely got to replace your torque convertor also. As for fitting I did a complete box swap in 3 hours so no more than £150 I would imagine for labour. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 7, 2013 Share Posted May 7, 2013 boxes should be cheaper than that mate, ive seen plenty of them under £200. normally £150 they sell for and some people have even given them away Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 7, 2013 Share Posted May 7, 2013 (edited) here is one http://www.mkivsupra.net/vbb/showthread.php?286483-J-spec-tt-auto-gearbox-and-parts-for-sale-%28-Price-Edited%29&highlight=autobox+sale this one here is sold but cheap http://www.mkivsupra.net/vbb/showthread.php?280383-Pre-Facelift-Autobox-from-TT-Jspec-TT&highlight=autobox+sale Edited May 7, 2013 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Lyall Posted May 7, 2013 Share Posted May 7, 2013 cheers for teh comments guys...It doesnt seem as bad now! I thought I was gonna need to fork out a couple of grand to to get it on the road!! I'll look into all of what u said!!! Quote Link to comment Share on other sites More sharing options...
keron Posted May 7, 2013 Share Posted May 7, 2013 If you get stuck... I have a tt auto and a na auto boxes in stock... Quote Link to comment Share on other sites More sharing options...
safcdixon Posted May 7, 2013 Share Posted May 7, 2013 Have you tried an oil and filter change? Quote Link to comment Share on other sites More sharing options...
Guest Lyall Posted May 7, 2013 Share Posted May 7, 2013 Cheers keron! I take it that a TT autobox wont fit a NA? Mine is NA. How much for a NA box? No not tried an oil and filter change. I had to put ATF fluid into to get it to the garage, there is fluid leaking right out of the box..would an oil and filter change fix this> Quote Link to comment Share on other sites More sharing options...
keron Posted May 7, 2013 Share Posted May 7, 2013 I have both in stock complete with t. Converters too...non turbo and twin turbo ones... Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 7, 2013 Share Posted May 7, 2013 Mate I would just take a NA box from Keron, a filter and fluid change wont fix the components burnt out from running it low. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 7, 2013 Share Posted May 7, 2013 I got my tt box from Keron, top service. As said boxes are so cheap, just replace and change fluid. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 8, 2013 Share Posted May 8, 2013 As mentioned in your other thread a good second hand transmission will be around the £300 mark, not to forget that if you have debris in your transmission then you have more than likely got to replace your torque convertor also. As for fitting I did a complete box swap in 3 hours so no more than £150 I would imagine for labour. did you actually change the box out your self ? Quote Link to comment Share on other sites More sharing options...
Guest Lyall Posted May 8, 2013 Share Posted May 8, 2013 As mentioned in your other thread a good second hand transmission will be around the £300 mark, not to forget that if you have debris in your transmission then you have more than likely got to replace your torque convertor also. As for fitting I did a complete box swap in 3 hours so no more than £150 I would imagine for labour. What is the torque convertor for? Is this to change it from NA to TT or the other way about? If I were to buy a NA box would I still need this? What I'm looking to find out is when I replace the autobox - would I need both the autobox and converter? is this anything else that I would need? Sorry for all the questions but I just dont want to go into it blind!! Cheers Lyall Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 8, 2013 Share Posted May 8, 2013 All auto-boxes have a torque converter mate it replaces the manual type clutch. Its a fluid coupling that transmits power from the engine to the driving wheels and multiples the torque. When you press the accelerator, the engine speeds up, fluid is pumped into the torque converter which transmits the power to the gearbox/wheels. In a nutshell anyway. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 8, 2013 Share Posted May 8, 2013 did you actually change the box out your self ? Yes mate. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 8, 2013 Share Posted May 8, 2013 how and with what tools? this is just so i know if i have to do mine Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 8, 2013 Share Posted May 8, 2013 how and with what tools? this is just so i know if i have to do mine I have a full size inspection pit in the garage so it made the job a few times easier, but basically I loaded a transmission jack underneith, unbolted the converter through the inspection hole, unbolted the gearbox (top 2 bolts you need a very long extension bar and go in from behind the box). Once these are all undone slide it back on the jack then lower slightly undoing all the connectors, then lower fully and off it is Not forgetting the gearbox mount bolts and cooler pipes but you know that Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 8, 2013 Share Posted May 8, 2013 i see the pit would help massively lol. Thanks for your imput though Quote Link to comment Share on other sites More sharing options...
Guest Lyall Posted May 8, 2013 Share Posted May 8, 2013 All auto-boxes have a torque converter mate it replaces the manual type clutch. Its a fluid coupling that transmits power from the engine to the driving wheels and multiples the torque. When you press the accelerator, the engine speeds up, fluid is pumped into the torque converter which transmits the power to the gearbox/wheels. In a nutshell anyway. Cheers mate. So I'll defo need a new one of those too then, cool. So all i'll need is the auto box and torque converter? Just so I know what to buy Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 8, 2013 Share Posted May 8, 2013 yes mate. Speak to Keron he can supply the lot. For piece of mind I would change the box filter and fluid. Makes a massive difference. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 9, 2013 Share Posted May 9, 2013 Easier just to replace it. There's one going cheap in the for sale section at the moment http://www.mkivsupra.net/vbb/showthread.php?t=290116 Quote Link to comment Share on other sites More sharing options...
