1993 Toyota supra non turbo breather problems
Guest Bumblebee25
Guest Bumblebee25
Hi all can anyone help me. On my car there is two breather pipes going from the inlet manifold down to just above/behind the starter motor. Can anyone name the thing that is a near the starter motor.
What's the problem?
There is a air tank thing with a vacuum switching valve on it and I think there is also a 2nd vacuum switching valve down there. The one with the tank is for the second butterfly valve on the inlet.
Ignore the parts for the EGR and DLC.
Guest Bumblebee25
Iam getting a lot of black smoke out the back and the revs are never settled when ticking over I thought two vacuum houses off this thing and I put them back on and it now cuts out I take one of the pipes off and it starts and runs with hardly no black smoke but still not working right. There is a block connector on this thing where the pipes go so I can only guess its on its way out but need to no what it is called so I can order a new one. Thanks for the pic I will have a look at it and see what I can find out
Try changing the pipes over as they need to be the right way round. I had a problem like this after I put the inlet manifold back on. Get a photo up of what you think the problem is and we can probably help a bit more.
