ManwithSupra Posted May 7, 2013 Share Posted May 7, 2013 (edited) Hi All, I am going to be replacing the Selector Seal on my V160 soon and as the Propshaft will be off I was thinking I may as well do the Output shaft seal as well mainly as these seals are now getting on for 20 years old and could probably do with replacing. Does anyone know what the recommended tool for removing the companion flange so I can get to the Output Shaft seal? I assume that the Output seal can be done while the box is in place? Edited May 7, 2013 by ManwithSupra (see edit history) Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 7, 2013 Author Share Posted May 7, 2013 Would any gear puller work (Like below) Quote Link to comment Share on other sites More sharing options...
SteveC Posted May 8, 2013 Share Posted May 8, 2013 If it's just the selector seal that's leaking, then personally I'd just replace that. The output shaft can be done at any time - IF it does ever decide to leak. The gearbox doesn't have to come off to change the output shaft seal. When the gearbox comes off to change the clutch, then it is worth changing the rear crankshaft seal and the gearbox input seal whilst the gearbox is off. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 8, 2013 Share Posted May 8, 2013 They are not usually all that tight to be honest mate. I swapped them between the R154 & the W58 while I was doing the conversion, neither took anymore than a gentle tap from behind and a small pry bar to remove. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 8, 2013 Author Share Posted May 8, 2013 They are not usually all that tight to be honest mate. I swapped them between the R154 & the W58 while I was doing the conversion, neither took anymore than a gentle tap from behind and a small pry bar to remove. Useful to know Cheers mate. Quote Link to comment Share on other sites More sharing options...
