Kaan W Posted May 6, 2013 Share Posted May 6, 2013 This is the E2 wire at pin 65 I am looking for, the manual says it should be a white/black wire but I have a brown one instead. Can anyone confirm that this is correct or do the colours vary on different models? Thanks Quote Link to comment Share on other sites More sharing options...
tomgeer Posted May 6, 2013 Share Posted May 6, 2013 Facelift non vvti and vvti ecu's definitely vary from the pre facelift j-spec, I think the uk spec is different again but not 100% sure Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 6, 2013 Author Share Posted May 6, 2013 Thanks, the manual I have downloaded and the one on the home page both show the colour should be white/black. Could I check by looking at all the sensor wires ie water temp, tps and check for either a brown ground or white/black ground? I have a UK spec btw. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 6, 2013 Author Share Posted May 6, 2013 Ok I have just found that the 97-98 models use a white/black ground and everything before uses a brown ground wire. Quote Link to comment Share on other sites More sharing options...
tomgeer Posted May 6, 2013 Share Posted May 6, 2013 (edited) Have you seen this document, is it any use to you? I found when wiring up my racelogic traction control that the ecu wire colours don't always tend to be what colour they should be when splicing into the wiring harness, but mine is a facelift non vvti model so yours should be easier to find the correct pinouts.UK spec pinouts.doc Edited May 6, 2013 by tomgeer (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 6, 2013 Author Share Posted May 6, 2013 Have you seen this document, is it any use to you? I found when wiring up my racelogic traction control that the ecu wire colours don't always tend to be what colour they should be when splicing into the wiring harness, but mine is a facelift non vvti model so yours should be easier to find the correct pinouts. Yeah I have that one mate but it dont say what the colours should be unfortunately. It was just a moment of confusion as looking at the manuals every wire was correct except this one which got me confused. Thanks for your help anyway Quote Link to comment Share on other sites More sharing options...
