Pulley Posted May 6, 2013 Share Posted May 6, 2013 Ok so, doing some road pulls (private roads) Up thru the gears and have set my boost controller for 1 bar high and .8 low setting Fuelling map seems spot on in all load situations Just wondered if any other 10-1 compression ratio NA-T guys out there can help confirm with afr figures At 1 bar I am getting a stable 10- 10.5 afr at wot Judging from lack of pink or knock and good egt this seems spot on to me Had lots of fun today in this amazing summer weather Hope everyone else is loving the supra shine All ready for japfest Quote Link to comment Share on other sites More sharing options...
Noz Posted May 6, 2013 Share Posted May 6, 2013 Get a dyno mate. Be great to know what your running. What's your timing like on full boost? Quote Link to comment Share on other sites More sharing options...
Pulley Posted May 6, 2013 Author Share Posted May 6, 2013 Get a dyno mate. Be great to know what your running. What's your timing like on full boost? Already know dyno figures at .8 bar , and that was 405bhp And now the system has been running fora while I have a different dyno lined up for my 1 bar output Egt and afr all seem stable, and it feels like it pulls much stronger at 1 bar Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 6, 2013 Share Posted May 6, 2013 Is 10- 10.5 abit rich, dont want to get bore wash Quote Link to comment Share on other sites More sharing options...
Pulley Posted May 6, 2013 Author Share Posted May 6, 2013 Is 10- 10.5 abit rich, dont want to get bore wash So you think 11, 11.5 should be better? I started out rich just to be safe Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 6, 2013 Share Posted May 6, 2013 11.5 is the total limit with knock detection, but I would always aim for 11-11.2 That being said you still ned to know the timing before just upping the boost even more so on a na/t. Quote Link to comment Share on other sites More sharing options...
Pulley Posted May 6, 2013 Author Share Posted May 6, 2013 11.5 is the total limit with knock detection, but I would always aim for 11-11.2 That being said you still ned to know the timing before just upping the boost even more so on a na/t. Cheers for the advice, I actually tuned my timing when I had the engine out, not such a realistic dyno as road and full drivetrain but I was able to "listen" to the ignition timing Only draw back of my fuelling is I'm unable to actively retard my timing I'm only running a crude additional injector controller on map and rpm curves After running a week or so on current fuelling and boost I endoscoped my bores and piston crowns and all looks great And given the varied testing (hills, motorways, varying loading pulls ) I can't be too far off I just wondered wot the afr figures should ideally be at 10-1 with .8- 1 bar boost Ideally soon I will be running lower compression Quote Link to comment Share on other sites More sharing options...
