Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 Hi guys fitted a 1st decat on my non turbo Sounds nice on tickover or light throttle But if you give it some it sounds like a vw Beatle pmsl Anyone else on here done the 1st decat If so what dose yours sound like Quote Link to comment Share on other sites More sharing options...
Fly Posted May 5, 2013 Share Posted May 5, 2013 I took out the 1st cat on myna but then I replaced it with a turbo down pipe ) still....sounds the business Quote Link to comment Share on other sites More sharing options...
berg Posted May 5, 2013 Share Posted May 5, 2013 Hi guys fitted a 1st decat on my non turbo Sounds nice on tickover or light throttle But if you give it some it sounds like a vw Beatle pmsl Anyone else on here done the 1st decat If so what dose yours sound like Yes mine did the exact same thing when i fitted my 2 decats What did you use to seal the first decat? Is it just the cat replacement pipe youve fitted or is it the manifold and decat in 1 version? Quote Link to comment Share on other sites More sharing options...
Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 I can't make it out mate mine sounds nice Until I give it some i have checked gaskets even thow There new Wifbiz decat £200 one so not cheap crap very tin type rasp sound Quote Link to comment Share on other sites More sharing options...
berg Posted May 5, 2013 Share Posted May 5, 2013 I have the exact same decat on mine What gaskets did you use as there are no gaskets supplied with the first decat (mine werent anyway) First time i fitted it i sized up some gaskets from mates work and fitted them and had the exact same noise you describe Took it off and used loctite 5920 on every joint on the whole exhaust and it has queitened down loads but i do still hear the noise Quote Link to comment Share on other sites More sharing options...
Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 Yes mine did the exact same thing when i fitted my 2 decats What did you use to seal the first decat? Is it just the cat replacement pipe youve fitted or is it the manifold and decat in 1 version? No mate its the one that whifbiz do so from 2nd cat upto manifolds Quote Link to comment Share on other sites More sharing options...
Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 Lol mate I did the same got some more new gaskets Then tryed exhaust paste The noise comes from the pipe without the flex part in it Must be the flow of exhaust gas or somthing then Quote Link to comment Share on other sites More sharing options...
berg Posted May 5, 2013 Share Posted May 5, 2013 Yer im thinking the same, ive had my whole exhaust and both decats off twice now and resealed with no real change Just fitted a 3" catback though so that does drown it out a bit Quote Link to comment Share on other sites More sharing options...
Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 (edited) And me mate hks dragger 3" upto first decat No loud like people make out Anyone reading this do not buy the all in one Off eBay manifold and decat as it will not fit I am sending it back to the USA company Crap still cost £200 Edited May 5, 2013 by White supra Add (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted May 5, 2013 Share Posted May 5, 2013 are the o2 sensors screwed in TIGHT with gaskets fitted? Quote Link to comment Share on other sites More sharing options...
Guest White supra Posted May 5, 2013 Share Posted May 5, 2013 are the o2 sensors screwed in TIGHT with gaskets fitted? I have bolt down type 02 sensors but yes and new gaskets mate Quote Link to comment Share on other sites More sharing options...
LOGIE Posted May 5, 2013 Share Posted May 5, 2013 I have bolt down type 02 sensors but yes and new gaskets mate Ah sorry yeah that's what I meant check they are tight though as the noise your describing sounds like they aren't tightened correctly. Quote Link to comment Share on other sites More sharing options...
