ManwithSupra Posted May 4, 2013 Share Posted May 4, 2013 Hi All, Just did a post track day check over and it looks like my V160 is seeping oil from the back of the gearbox (near the prop shaft). I have heard that it could be the gear selector shaft leaking fluid. Is there a how to on how to replace this oil seal and what part number do I need to purchase? Rich Quote Link to comment Share on other sites More sharing options...
Geo Posted May 4, 2013 Share Posted May 4, 2013 rear seal. Chris wilson does replacments only a few quid, his are uprated also. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 4, 2013 Share Posted May 4, 2013 Oil leaks at the back of the v160 are most commonly caused by the shifter seal not the output shaft seal. They are very tricky to replace so the tried and tested workaround is to have a 2nd one pushed over the top. My old one had that done 10 years ago and it's not leaked since. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 4, 2013 Author Share Posted May 4, 2013 Oil leaks at the back of the v160 are most commonly caused by the shifter seal not the output shaft seal. They are very tricky to replace so the tried and tested workaround is to have a 2nd one pushed over the top. My old one had that done 10 years ago and it's not leaked since. Cheers mate, do you know what part number I need to order and perhaps any details on a how to? A search didn't turn anything up. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 4, 2013 Share Posted May 4, 2013 Cheers mate, do you know what part number I need to order and perhaps any details on a how to? A search didn't turn anything up. Just had a look on Toyodiy.com and found the following: 90080-31029 - SEAL, OIL(FOR MANUAL TRANSMISSION EXTENSION HOUSING) - €30.95 - Thats the output shaft seal 90080-31032 - *** STD. PART - €9.21 - I *think* this is the selector seal, but it's not entirely clear from the picture The likes of Chris Wilson, Whifbitz, etc will likely have these in stock so best to contact them. For the selector seal it simply needs to be pushed into place over the top of the existing one. Since the selector and prop will need to come out you might as well do them both. Again CW, Whifbitz or others will be familiar with this, so best to ask them for confirmation if you order parts from them Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 5, 2013 Share Posted May 5, 2013 In stock here yep. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 6, 2013 Author Share Posted May 6, 2013 In stock here yep. Cool how much mate? May as well do both seals :-) Quote Link to comment Share on other sites More sharing options...
Westy Posted November 1, 2013 Share Posted November 1, 2013 In stock here yep. Can you PM me a price for both seals also please Paul. Noticed a slight leak on the rear of my V160 today whilst doing my oil change. Quote Link to comment Share on other sites More sharing options...
