girth45 Posted May 4, 2013 Share Posted May 4, 2013 Hi, going to be changing my brake pads front and rear soon, my car is a 98 vvti TT, with UK callipers and discs, any recomendations, want low dust, but v good performance, only had car a couple of weeks, thanks in advance. Gary. Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted May 4, 2013 Share Posted May 4, 2013 Chris Wilson is your man for this sort of advice. Will supply as well! Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 4, 2013 Share Posted May 4, 2013 (edited) Toyota brake pads work just fine If not done recently i'd do a fluid change and a thorough inspection of the calipers when you have the pads out. Check the outer seals for splits or holes as this will let moister and dirt get down the side of the piston and cause them to seize. Check the pistons move in and out freely Spray tin brake cleaner (Halfords) and a tooth brush (Boots) work wonders to shift all the brake dust etc Edited May 4, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
girth45 Posted May 4, 2013 Author Share Posted May 4, 2013 Thanks dunk, good advice. Quote Link to comment Share on other sites More sharing options...
ellis Posted May 4, 2013 Share Posted May 4, 2013 Chris Wilson is your man for this sort of advice. Will supply as well! +1 for his fast road pads Quote Link to comment Share on other sites More sharing options...
girth45 Posted May 4, 2013 Author Share Posted May 4, 2013 Thanks Ellis. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 4, 2013 Share Posted May 4, 2013 Just fitted some CW pads; second set I've had and both work fantastically. Seem to produce an average level of dust, but doesn't take 2 mins to wipe the wheel down. Doubt you will get anything better or equal with less dust. Quote Link to comment Share on other sites More sharing options...
girth45 Posted May 4, 2013 Author Share Posted May 4, 2013 Where do I get these cw pads from? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 4, 2013 Share Posted May 4, 2013 Where do I get these cw pads from? -> Chris Wilson Quote Link to comment Share on other sites More sharing options...
girth45 Posted May 4, 2013 Author Share Posted May 4, 2013 Pmd Chris Wilson, thanks. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 4, 2013 Share Posted May 4, 2013 Pmd Chris Wilson, thanks. I'd email him instead, see his sig. Quote Link to comment Share on other sites More sharing options...
