Uk drivetrain?
Mace
I'm going to fit the engine, gearbox and diff from a uk spec TT auto into my 1993 N/A auto. Before I start are there any compatablity issues i'm going to face because its uk spec? are the diffs the same as i was told the uk diff is larger? anything else worth taking from the uk spec? apart from brakes..
Everything you need to know for a NA-TT swap is right here.
http://www.mkivsupra.net/vbb/showthread.php?136136-NA-to-TT-engine-transplant-step-by-step-guide-(Pic-heavy)
Took me literally 30 seconds to find it using the search bar :p
Iirc the props need to be swapped too. Diff I'm not sure, but if its lower mileage, and swap it regardless :)
Edited by listy (see edit history)
Yeah seen that good guide. Thanks.. Diff is LSD mine is open diff, I take it the mounts are all the same? dont need to swap rear subframes or anything like that?.. just trying to find out before I strip the car, dont want to scrap anything I need later on..
Edited by Mace (see edit history)
