Mace Posted May 4, 2013 Share Posted May 4, 2013 I'm going to fit the engine, gearbox and diff from a uk spec TT auto into my 1993 N/A auto. Before I start are there any compatablity issues i'm going to face because its uk spec? are the diffs the same as i was told the uk diff is larger? anything else worth taking from the uk spec? apart from brakes.. Quote Link to comment Share on other sites More sharing options...
listy Posted May 4, 2013 Share Posted May 4, 2013 (edited) Everything you need to know for a NA-TT swap is right here. http://www.mkivsupra.net/vbb/showthread.php?136136-NA-to-TT-engine-transplant-step-by-step-guide-(Pic-heavy) Took me literally 30 seconds to find it using the search bar Iirc the props need to be swapped too. Diff I'm not sure, but if its lower mileage, and swap it regardless Edited May 4, 2013 by listy (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 4, 2013 Share Posted May 4, 2013 (edited) Engine & transmission looms, ECU, rev counter, propshaft, n/s drive-shaft and 1st cat. Edited May 4, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Mace Posted May 4, 2013 Author Share Posted May 4, 2013 (edited) Yeah seen that good guide. Thanks.. Diff is LSD mine is open diff, I take it the mounts are all the same? dont need to swap rear subframes or anything like that?.. just trying to find out before I strip the car, dont want to scrap anything I need later on.. Edited May 4, 2013 by Mace (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 4, 2013 Share Posted May 4, 2013 Thank you for reminding me not to answer questions. Quote Link to comment Share on other sites More sharing options...
