matthewswinimer Posted May 4, 2013 Share Posted May 4, 2013 hi i have to install a clutch switch for safty inspection here in canada. my j spec supra does not have one from factory so iam asking what would be good wire to splice the clutch switch into? thanks in advance! Link to comment Share on other sites More sharing options...
Josh42 Posted May 4, 2013 Share Posted May 4, 2013 When you say clutch switch, could you be a little more specific please my friend? Link to comment Share on other sites More sharing options...
matthewswinimer Posted May 4, 2013 Author Share Posted May 4, 2013 When you say clutch switch, could you be a little more specific please my friend? the switch under the clutch peddle that will let the car start only if clutch peddle is pressed in.iam pretty sure the uk version come factory with them but not the j spec. i purchased the factory switch from toyota and have it installed but dont know what wire i should cut and divert to the switch. there must be an ignition wire somwhere close...... Link to comment Share on other sites More sharing options...
Josh42 Posted May 4, 2013 Share Posted May 4, 2013 (edited) Ahh you mean an inhibitor switch.... When I did my auto to manual conversion, I had to splice two wires together on the loom where it connects to the gearbox...this fools the ecu into thinking the car is in neutral. I didn't realise there was a switch under the pedal even on UK's.... Edited May 4, 2013 by Josh42 (see edit history) Link to comment Share on other sites More sharing options...
matthewswinimer Posted May 5, 2013 Author Share Posted May 5, 2013 Ahh you mean an inhibitor switch.... When I did my auto to manual conversion, I had to splice two wires together on the loom where it connects to the gearbox...this fools the ecu into thinking the car is in neutral. I didn't realise there was a switch under the pedal even on UK's.... // ok but i dont wana fool anything. i actually need it hooked up.......someone must know of a ignition wire that can be cut and routed through the clutch switch?? Link to comment Share on other sites More sharing options...
listy Posted May 5, 2013 Share Posted May 5, 2013 Surely putting a push switch into the positive ignition wire is the simplest way? Extend the wire so it goes under the clutch, job done. Seems straight forward in my just woken up head, waiting for someone to tell me NO lol Link to comment Share on other sites More sharing options...
