Need help from gurus hks fcd fault
SUPRAPAUL
Ok I've searched and read all install guides, tried settings 7and 9,
I followed the install guide and I found car was running on fuel cut straight away!! I let the car idle for 10 mins before road testing but still hitting fuel cut i Disconnect and re join boost pressure wire all ok,
I ran a separate live and earth checking for volt drop still the same,
Changing the setting made no difference
I've read several posts of people having same fault but with no solution
The cars a mkiv rz-s 6 speed j-spec
Please any help would much appreciate.
