Josh42 Posted May 1, 2013 Share Posted May 1, 2013 Okay guys, I'm about ready to donate the car to the next passer by. I've been trying to remove the rear lower arm (no.2) for about a week now. I ended up grinding the subframe end out, but now I'm stuck again as the ball joint WILL NOT come out of the back of the hub. I've tried WD40, I've tried a 4lb lump hammer and I've tried a blow torch. Any other ideas? Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 1, 2013 Share Posted May 1, 2013 Leaver bar! Failing that more HEAT and a hammer! Quote Link to comment Share on other sites More sharing options...
safcdixon Posted May 1, 2013 Share Posted May 1, 2013 Stihl saw Can it not be pressed out if you remove the whole Hub Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 1, 2013 Author Share Posted May 1, 2013 That was my next plan...to remove the hub and take it into work and use one of our presses.... Was just wondering if anyone else had any recommendations before I go through the heartache of removing the hub and potentially hitting this same snag with all the other arms:( Quote Link to comment Share on other sites More sharing options...
safcdixon Posted May 1, 2013 Share Posted May 1, 2013 As chris says Lots of heat should help but you may risk cracking the cast hub if you hit it too hard Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 1, 2013 Share Posted May 1, 2013 As chris says Lots of heat should help but you may risk cracking the cast hub if you hit it too hard We have this trouble at work when doing wheel bearings on Renault Masters, Always heat it up till its red hot. Use a very big 30+mm socket and hit it with a hammer. 8/10 it comes out! Quote Link to comment Share on other sites More sharing options...
safcdixon Posted May 1, 2013 Share Posted May 1, 2013 We have this trouble at work when doing wheel bearings on Renault Masters, Always heat it up till its red hot. Use a very big 30+mm socket and hit it with a hammer. 8/10 it comes out! Get the Oxy acetylene out!! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 1, 2013 Author Share Posted May 1, 2013 I've got a gas blow torch and been heating it.. Ill give it another go tomorrow evening and see how I get on. If not, hub is coming off! Cheers both! Quote Link to comment Share on other sites More sharing options...
