Johnny176 Posted May 1, 2013 Share Posted May 1, 2013 Evening guys, My rear offside shock has started to leak oil. It is becoming more and more noticeable over the last 2 weeks with the car feeling unstable at the rear when taking corners and as if its very soft when driving over dips and humps on the road. I'm unsure if I should get new rear shocks, not sure where from tho. Or to go with a new set of coilovers, again not sure what to get. Can anyone recommend anything? I'm not looking to lower the car as veilside skirts don't leave me much clearance as it is and I don't want to go overkill on shocks since I don't track the car. Something slightly firmer to improve handling would be ideal tho Thanks Quote Link to comment Share on other sites More sharing options...
DODGYDODDS Posted May 1, 2013 Share Posted May 1, 2013 Could you not get yours rebuilt bud? I have just had to replace my sus, I went for meister r coilovers to replace my damaged hks hipermax's. they arrived today so not fitted them yet. But the reviews are good and their customer service is first rate. Build quality is excellent, the fronts have pillowball bearings. And the spring rates being 14kg front 8kg rear will help on our bad roads. My 2 pence worth Quote Link to comment Share on other sites More sharing options...
Nic Posted May 1, 2013 Share Posted May 1, 2013 I'd get yourself a set of OEM Toyota/Bilstein dampers. 2 x 48510-09016 Toyota/Bilstein Damper 2 x 48530-09016 Toyota/Bilstein Damper Quote Link to comment Share on other sites More sharing options...
Johnny176 Posted May 1, 2013 Author Share Posted May 1, 2013 I wasn't too sure what I could do with them tbh, thought I'd start by asking here I had thought of taking the opportunity of getting an aftermarket set of coilovers since they are on the way out and there's a good chance another could go as well. I'll give them a google Where would you recommend getting OEM dampers from Nic? Is that a Toyota dealer thing? Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 1, 2013 Share Posted May 1, 2013 Try googling bilstein and by direct from them. All for shocks should be around the £400-£500 mark. If you go to Toyota for the bilstein shock they will charge you couple of hundred pounds more just for them saying Toyota on them Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 1, 2013 Share Posted May 1, 2013 You can get a full set of fully adjustable BC Racing coilovers for £500 Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 1, 2013 Share Posted May 1, 2013 You can get a full set of fully adjustable BC Racing coilovers for £500 You can if you don't mind the dampers given up on you when you push them to much. You can't really beat the standard bilstein damper unless your willing to spend a couple of grand for a coilover system Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 1, 2013 Share Posted May 1, 2013 You can if you don't mind the dampers given up on you when you push them to much. You can't really beat the standard bilstein damper unless your willing to spend a couple of grand for a coilover system BC get a good rating on the forum - Have you had troubles with them yourself? I doubt anyone pushes them to there maximum on the street? Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 1, 2013 Share Posted May 1, 2013 BC get a good rating on the forum - Have you had troubles with them yourself? I doubt anyone pushes them to there maximum on the street? Not with the BC but with the Tein monoflex which is pretty much the same thing with a higher price tag. I found they gave the apperence of better handling by upping the spring rate to reduce body roll. But when pushed the dampers gave up. I guess if your not a driver that pushes your car then the system like BC, HSD, ect are fine and are well worth the money. But if you like to push and don't want to spend a small fortune on a system then i would say the bilstein set up is the best you can get. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted May 1, 2013 Share Posted May 1, 2013 got mine from chris wilson, toyota is stupid money, and i mean stupid money. you be suprised just how much the rubber insulators are for the new shocks if your old ones are toast ( the rubber covers over the shock) £70+ from toyota for the pair. bilsteins from toyota are about £470 for the rear 2 only, no covers just the shocks. pm chris wilson Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 1, 2013 Share Posted May 1, 2013 Not with the BC but with the Tein monoflex which is pretty much the same thing with a higher price tag. I found they gave the apperence of better handling by upping the spring rate to reduce body roll. But when pushed the dampers gave up. I guess if your not a driver that pushes your car then the system like BC, HSD, ect are fine and are well worth the money. But if you like to push and don't want to spend a small fortune on a system then i would say the bilstein set up is the best you can get. He said he's not going to do trackdays in the car etc, So the BC Racing setup will be fine. Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 2, 2013 Share Posted May 2, 2013 Bilsteins win hands down for me, over 100k on mine before a rear decided it wanted to retire. They can do track days too Speak to Chris Wilson as Toyota are £186 + vat each Quote Link to comment Share on other sites More sharing options...
SPG Posted May 2, 2013 Share Posted May 2, 2013 I have a set of yellow Billies coming off my supra this weekend, come with standard TT springs also. Let me know if you are interested Quote Link to comment Share on other sites More sharing options...
Johnny176 Posted May 7, 2013 Author Share Posted May 7, 2013 Thread revival! Thanks for the advice guys. As I said, I was thinking about upgrading since I'm replacing the rear 2 anyways but fastcar and Dnk you say the Bilstein shocks are a good job? I did a quick google search for someone selling these but just got ebay links... I'll drop Chris a PM I checked out those BC coilovers Chris, closest I could find was these? http://www.bc-racing.co.uk/applications/toyota-coilovers/toyota-supra-jza80-93-98/br-series-coilover-type-rs-1.html I haven't been out in the car since I've been busy with work but there's another few drops of oil under the rear driverside again. I'm aiming to get it sorted before our 2 weeks of summer hits Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 7, 2013 Share Posted May 7, 2013 Thread revival! Thanks for the advice guys. As I said, I was thinking about upgrading since I'm replacing the rear 2 anyways but fastcar and Dnk you say the Bilstein shocks are a good job? I did a quick google search for someone selling these but just got ebay links... I'll drop Chris a PM I checked out those BC coilovers Chris, closest I could find was these? http://www.bc-racing.co.uk/applications/toyota-coilovers/toyota-supra-jza80-93-98/br-series-coilover-type-rs-1.html I haven't been out in the car since I've been busy with work but there's another few drops of oil under the rear driverside again. I'm aiming to get it sorted before our 2 weeks of summer hits You'd be better off calling Chris as he's not a fan of pm, his contact details are in his sig Quote Link to comment Share on other sites More sharing options...
