12v fuel pump mod....is it needed?
matthewswinimer
hi there i will be switching to ttc and wondering if the 12v fuel pump mod is needed? ive read it burns up fuel pumps...and after buying a walbro dont really wanna burn it up.but i dont wanna run lean either during the transition the fuel pump makes from 8v to 12v either.
ps i do have a greddy fcd installed already if that matters
thanks in advance for your comments!
ttc stands for true twin conversion. its when both turbos spool together rather then 1 and the 2nd kicks in after(sequential)
and yes iam factory tt
Wow never heard that before! That's not normally beneficial due to the extra lag. Normally only na/t guys use the 12v mod so can't help you on a Tt I'm afraid. Anyone else shed anymore light on this?
the only reason to use the 12v mod is to make a larger pump work correctly a 300lph walbro is fine with stock set up! i had to do the mod to get my 400lph walbro working but that could of also been a bad fuel pump imobilser wire earthing out
so to sum up you should be fine with the stock set up :D
IIRC TTC can run ever so slightly lean at 1 points but nothing to worry about. 12v fuel pump mod would not be required in the situation and would prob be advised against as it ca reduce the life of a pump.
Toyota got it so right, I would suggest only changing what you have to.
Please have a quick search as its been many years since I was TTC.
The only real benefit people have seen by going TTC is when they have had it running on an aftermarket ecu. In the UK the best results have been found by running TTC and a Syvecs ecu.
I can't think of anyone that has liked the performance from TTC on a stock ecu. Maybe something to consider.
Or....if you are worried about the second turbo having a hard life, swap tubby 1 and tubby 2 over, so they both get even wear.
you cant swap them there totally different turbo housings ;)
If anything it's the first turbo that gets all the abuse as it runs all the time, the second one only above 4000rpm. There is a prespool system that brings it in but that's only to stop all the boost from #1 disappearing backwards through #2 when it comes online.
The idea of somehow "smashing" #2 is ridiculous in the first place though, they are built to spin up as fast as possible, that means less lag. The valve opening to expose #2 to exhaust gas is exactly the same as someone accelerating and suddenly feeding a turbo with exhaust gas.
And no, you don't need the 12v mod, do we really still talk about this? The pump goes 12v when you see positive boost anyway, you'd only increase the off-boost voltage, so pointless.
