Post a picture of your EGT probe on stock manifold
Kristian_Wraae
Number one runner, as close to the head flange as possible. Manifold material is about 4mm thick, assuming stock T setup. Tap 1/8 BSP for most common probe adaptors, but check first! I've done dozens and made up some special tooling to make it easier. Like a long tap extension.
  • 2 weeks later...
I need to know a little more about where to tap it.
Do you tap it at an angle and in front of the first upper exhaust stud? Outside the heatshield ? Or do you remove the heatshield and tap it straight down to the rear of the first upper exhaust stud?
If it is in front of the first exhaust stud I guess Í need to place probe at an angle (like 45 degrees - down and pointing back and towards the intake side). Then it should be possible to tap it by only removing the y-pipe going to the intercooler and keep the heatshield in place. What do you think?
You cut a section of the heat shield away, and drill straight down, about 12 mm in towards the RH wing side of the car, (so you leave enough space to get the adaptor in, with a socket on it). The probe is vertical, then bend the lead at a gentle angle, and coil any surplus up in a loop no LESS than 6 inch diameter.
Sorry to jump in on your thread but I'm looking at doing this on a single manifold and thought best place was in no6? Is it different for stock?
Given free choice the BEST place is at the confluence of all six runners, just before the turbo itself.
Ok cool thanks mate I just thought no6 as its generally the hottest of the lot. Will have a look at my manifold and see if that possible :)
You could drill and tap the turbine housing itself and put an Inconel probe in there. You MUST use an Inconel probe before the turbo, as the heat can soften stainless steel ones and the tip can fall off and go through the turbo, ruining it.
Thanks mate do you have a recomended source for such a probe?
