Kaan W Posted May 13, 2013 Author Share Posted May 13, 2013 Maybe an aftermarket one is easier for plumbing an FMIC. But seriously, don't aftermarket ones come with bigger throttle diameters? You can have any size throttle body you want but I think stock sized is best for most power goals IMO. Link to comment Share on other sites More sharing options...
Gaz6002 Posted May 13, 2013 Share Posted May 13, 2013 Edit: Can you please explain to me why aftermarket manifolds don't help increase power? Will it not be a good idea as a forum to explain these things for people to learn? Sure, it's because I'm wrong and I didn't read your thread properly. I thought you were talking about 'induction kits' as opposed to the stock intake system using the cold air box. Link to comment Share on other sites More sharing options...
Luxluc Posted May 13, 2013 Share Posted May 13, 2013 Some people run big power through the stock plenum. Some say you have increased lag due to large plenums. Concrete proofs (dyno test of different intake setups) are however missing. I know that Jamie tested his old 67mm setup with stock intake vs GReddy plenum...and gained around 40bhp. My old setup pushed 626 bhp on stock intake @1.5 bar, and 651rhhp @1.8 bar with GReddy plenum. How to compare bhp vs rhhp is another discussion topic. Link to comment Share on other sites More sharing options...
Kaan W Posted May 13, 2013 Author Share Posted May 13, 2013 Some people run big power through the stock plenum. Some say you have increased lag due to large plenums. Concrete proofs (dyno test of different intake setups) are however missing. I know that Jamie tested his old 67mm setup with stock intake vs GReddy plenum...and gained around 40bhp. My old setup pushed 626 bhp on stock intake @1.5 bar, and 651rhhp @1.8 bar with GReddy plenum. How to compare bhp vs rhhp is another discussion topic. Thats what I read, I would like to see the difference in gains on various manifolds for the same engine too. Ive just been speaking with Sean at Titan and he said the billet mains would be pointless for my build so I will stick with the stock caps, you'll be ok though you have a room to grow with the 6 speed Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 13, 2013 Share Posted May 13, 2013 Thats what I read, I would like to see the difference in gains on various manifolds for the same engine too. Ive just been speaking with Sean at Titan and he said the billet mains would be pointless for my build so I will stick with the stock caps, you'll be ok though you have a room to grow with the 6 speed Did he explain why they would be pointless? Link to comment Share on other sites More sharing options...
Kaan W Posted May 13, 2013 Author Share Posted May 13, 2013 Did he explain why they would be pointless? He just said its something to consider when going beyond 1100hp which I definately wont be doing Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 13, 2013 Share Posted May 13, 2013 He just said its something to consider when going beyond 1100hp which I definately wont be doing Fair doo's - So what modifcations will you be doing to the engine block? Link to comment Share on other sites More sharing options...
Kaan W Posted May 13, 2013 Author Share Posted May 13, 2013 Fair doo's - So what modifcations will you be doing to the engine block? Just a general rebuild with some uprated parts as my engine's getting on a bit now. I will post in my project thread when the new parts arrive incase I change my mind again Link to comment Share on other sites More sharing options...
Slutters Posted May 13, 2013 Share Posted May 13, 2013 Some people run big power through the stock plenum. Some say you have increased lag due to large plenums. Concrete proofs (dyno test of different intake setups) are however missing. I know that Jamie tested his old 67mm setup with stock intake vs GReddy plenum...and gained around 40bhp. I take it something else changed too? In my opinion there's no way that's possible! Link to comment Share on other sites More sharing options...
Kaan W Posted May 13, 2013 Author Share Posted May 13, 2013 I take it something else changed too? In my opinion there's no way that's possible! At a total guess I think its more down to how much boost can be achieved without leaning out a particular cylinder from un even air distribution. Link to comment Share on other sites More sharing options...
Kaan W Posted May 16, 2013 Author Share Posted May 16, 2013 Sooo, after taking my time to decide on what parts to use bearing in mind my goals I have settled on, and ordered the following - L19 Headstuds ARP Main studs Titan billet cam belt tensioner Titan Crank pulley Titan welded crank gear New oil pump New water pump Full engine gasket set CP 86.5mm 8.5:1 pistons BC625+ Pro rods Gates timing belt ACL bearings And some bling The next plan is to have this lot sent off with my new block for machining and assembling ready for me to finally start building on. I will post updates in my project thread when this starts Link to comment Share on other sites More sharing options...
Luxluc Posted May 17, 2013 Share Posted May 17, 2013 Great spec list mate. Well done Link to comment Share on other sites More sharing options...
Kaan W Posted May 17, 2013 Author Share Posted May 17, 2013 Great spec list mate. Well done Cheers Luc Really looking forward to building it and hope I can stick to my deadline and have it all finished for next year Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 17, 2013 Share Posted May 17, 2013 Nice spec mate. Should be a great little engine once done. Link to comment Share on other sites More sharing options...
mark newman Posted May 17, 2013 Share Posted May 17, 2013 I would go with better rods . Link to comment Share on other sites More sharing options...
Kaan W Posted May 17, 2013 Author Share Posted May 17, 2013 I would go with better rods . What rods would you recommend? Wern't these the same rods Jamie had in his supra? Link to comment Share on other sites More sharing options...
mark newman Posted May 17, 2013 Share Posted May 17, 2013 this what you want Carrilo H-beam Conrods paul will do you a nice price . Link to comment Share on other sites More sharing options...
Kaan W Posted May 17, 2013 Author Share Posted May 17, 2013 this what you want Carrilo H-beam Conrods paul will do you a nice price . Nice rods but as im not going for alot of power I think the rods ive ordered will be fine, rated at 1800hp (may be a little optamistic) but many people have used these on big power builds without issues if built correctly. If I insisted on having the best possible parts it will be a very expensive and overkill build for my goals. Link to comment Share on other sites More sharing options...
mark newman Posted May 17, 2013 Share Posted May 17, 2013 1800hp well they must be good then . Link to comment Share on other sites More sharing options...
Kaan W Posted May 17, 2013 Author Share Posted May 17, 2013 1800hp well they must be good then . Im sure they will be fine. Link to comment Share on other sites More sharing options...
mark newman Posted May 17, 2013 Share Posted May 17, 2013 no need for billet main caps then Link to comment Share on other sites More sharing options...
Kaan W Posted May 17, 2013 Author Share Posted May 17, 2013 no need for billet main caps then They are only needed for 1000+hp so I should be ok. Link to comment Share on other sites More sharing options...
Kaan W Posted May 18, 2013 Author Share Posted May 18, 2013 Im thinking of using a lightened flywheel as im trying to get as much torque and response from the engine as possible with as small turbo as possible. Anyone use one? Opinions? Link to comment Share on other sites More sharing options...
Luxluc Posted May 19, 2013 Share Posted May 19, 2013 I have used my RPS max 6 puck clutch with the RPS lightened flywheel. I liked it, and the slight rattle between 1800-2300 rpm isn't really that much. My RPS triple carbon comes with a lightened flywheel as well...but I'm not bothered. Luc Link to comment Share on other sites More sharing options...
Kaan W Posted May 19, 2013 Author Share Posted May 19, 2013 I have used my RPS max 6 puck clutch with the RPS lightened flywheel. I liked it, and the slight rattle between 1800-2300 rpm isn't really that much. My RPS triple carbon comes with a lightened flywheel as well...but I'm not bothered. Luc I'm not bothered if it rattles slightly with the amount of other noises going on, does it rev noticeably quicker with the lightened flywheel? Link to comment Share on other sites More sharing options...
