peter richards Posted April 28, 2013 Share Posted April 28, 2013 guys posted up a question a few months back , where my bonnet wasn't sitting tight on the drivers side , fiddled about abit with it , but its still not right and comes open when driving . so whats my options here I don't think it adjusts and I don't feel 100% safe with it like it is .and not sure on the aerocatches . advice appreciated peter Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 28, 2013 Share Posted April 28, 2013 You could try a new/newer set, they are easy enough to change over, aerocatches are ideal though theres no way they are going to open when driving Quote Link to comment Share on other sites More sharing options...
peter richards Posted April 28, 2013 Author Share Posted April 28, 2013 don't like the look of the areos on the bonnet tbh , ill see if keron has some normal ones Quote Link to comment Share on other sites More sharing options...
straightsix Posted April 28, 2013 Share Posted April 28, 2013 Did you use different blots when adjusting the bonnet catch? The originals are self centering so you need to swap them for normal bolts or you won't get any degree of adjustment on the catch. Quote Link to comment Share on other sites More sharing options...
peter richards Posted April 28, 2013 Author Share Posted April 28, 2013 no , not tried that , sometimes its ok and the lever inside goes flush , and its down , but then pops up again over bumps so bit afraid atm that if im going fast it might blow over Quote Link to comment Share on other sites More sharing options...
straightsix Posted April 29, 2013 Share Posted April 29, 2013 Try swapping the bolts then and adjust the catch upwards to engage the loop on the bonnet properly. You might also have to screw the rubber stops in a little more. You'll have to play around with it to get it right Quote Link to comment Share on other sites More sharing options...
