jjs_82 Posted April 28, 2013 Share Posted April 28, 2013 Hi all I need some help i have a slight misfire on high boost (1.15 bar) i have new coil pack clips and new ngk bkr7eix spark plugs in her. Car is a 98 vvti tt anyone have any idea. Do i need new coil packs Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted April 28, 2013 Share Posted April 28, 2013 Did this start happening after u changed the plugs? First question will always be, what changed right before a problem started? Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted April 28, 2013 Share Posted April 28, 2013 (edited) Fueling issue? Did you upgrade the fuel pump from stock? I would then double check the clips you replace to make sure they are all correct. ^^ I've checked the FAQ section and those plugs are rated for BPU with gaps unchanged. We're they brand new? Edited April 28, 2013 by mwilkinson (see edit history) Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted April 28, 2013 Author Share Posted April 28, 2013 It just came on her one day thats why i got the new plugs and clips. I have a new bosch 044 but that was in her before the misfire came along. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted April 28, 2013 Share Posted April 28, 2013 Easy thing to do to see if it is a boost related issue is to dial back the boost and see it still happens. Failing that find another member who will let you swap coil packs over and see if it still occurs. Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted April 28, 2013 Author Share Posted April 28, 2013 Ok when i have my foot to the floor i have the misfire but if i let off a bit the misfire stops. So that would be me letting the boost drop off a bit Quote Link to comment Share on other sites More sharing options...
listy Posted April 28, 2013 Share Posted April 28, 2013 I have a similar problem but only after a very short journey. On longer journeys, or if I leave the car running a couple of minutes after, it doesn't happen. I've changed plugs and clips too. My next step is to remove the O2 sensor and replace with a new one. After that, I think the only other option is new coil packs Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted April 28, 2013 Author Share Posted April 28, 2013 I have a new 02 sensor in my one. My one is at it all the time Quote Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2013 Share Posted April 28, 2013 I'd start by double checking all the coil pack connectors are secure, i'd then try fitting a set of cheap cooler grade plugs (NGK BKR8E) gapped 0.7mm. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2013 Share Posted April 28, 2013 My next step is to remove the O2 sensor and replace with a new one. The O2 sensor only effects fuelling at low rpm when in closed loop, it won't cause a misfire at higher rpm on boost. What plugs do you have fitted? Quote Link to comment Share on other sites More sharing options...
listy Posted April 28, 2013 Share Posted April 28, 2013 I have BKR7EIX Iridiums. The recommended plugs for BPU. Mine only seems to occur after very short trips though. (A mile or two to the shops) I thought it may be over fuelling, affecting the spark? Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted April 28, 2013 Author Share Posted April 28, 2013 So you think the NGK 8 will help Quote Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2013 Share Posted April 28, 2013 So you think the NGK 8 will help It *may* be the plugs causing the misfire, for the relatively low cost it'd be worth trying a standard set of cooler grade plugs to see if it does make a difference, Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 28, 2013 Share Posted April 28, 2013 I have a cold missfire idle fine if I drive missfires bad sometime nearly cuts out, but after it warm say 5 minutes its perfict also if I floor it when its missfiring I get into boost and its fine really odd, could a temp sensor cause it, I have new clips, plugs, o2, Its getting on my nervse abit now, could a igniter be on its way out any thoughts? Quote Link to comment Share on other sites More sharing options...
Guest RJAfarrier Posted April 29, 2013 Share Posted April 29, 2013 i have this very same problem, mis-fire on boost. i have a 95 auto with 165000km on the clock. what was the mileage of your car when the problem started? would it seem this problem is becoming common around a certain mileage? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 29, 2013 Share Posted April 29, 2013 What about the coil packs ? Quote Link to comment Share on other sites More sharing options...
alex341 Posted April 29, 2013 Share Posted April 29, 2013 Mine does the same thing just before 2nd turbo kicks in but only if ive been driving around off boost then floor it, if i rev it throught the gears its fine....? Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted April 29, 2013 Author Share Posted April 29, 2013 My one has about 94000kms. I was just thinking about getting 3 new coil packs Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 30, 2013 Share Posted April 30, 2013 alot of the second turbo stuff could be just the coil pack clips or wrong plugs or fuel pump depends if it was bpu'ed correctly Quote Link to comment Share on other sites More sharing options...
j.oe Posted April 30, 2013 Share Posted April 30, 2013 The problem should relate to the 1,1 mm gap those plugs originally have. Gap them to 0,6 mm and all will be fine. Had the same issue on mine. Quote Link to comment Share on other sites More sharing options...
Slippery Posted April 30, 2013 Share Posted April 30, 2013 In the last year and half I have developed a misfire twice and both times it turned out to be my brand new supersparx coil packs. Both sets did less than 1500 miles. Fitted old Toyota ones and as good as gold since. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 1, 2013 Share Posted May 1, 2013 In the last year and half I have developed a misfire twice and both times it turned out to be my brand new supersparx coil packs. Both sets did less than 1500 miles. Fitted old Toyota ones and as good as gold since. intresting as i have superparx and a cold satrt miss , maybe something to check Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted July 23, 2013 Author Share Posted July 23, 2013 Well everyone my misfire is gone. I got 3 new coil packs and new plugs. Have the in 2 days now and going good. Quote Link to comment Share on other sites More sharing options...
