Electric windows no power?
Scott-tt
I'm building a rolling shell and everything else has worked ok so far but I can't get the window motors to operate they seem to be connecting up ok but is there a control box or something any help much appreciated guys
I had the same problem, the motor spins a plastic cog, which then operates the air cords. it turned out the teeth on the plastic cog had slightly worn down and was jamming the window. take the metal cover off and check it out :)
