adarmo Posted April 27, 2013 Share Posted April 27, 2013 Hi, My steering wheel (NA facelift) has a bit of up and down play in it (couple of mm)- is this usual due to the tilt facility ? Also something doesn't feel right when driving it I can't tell what exactly, just that something isn't right. It's most obvious when reversing out of a parking space and turning the wheel quickly and it feels like there is gravel in the rack - not the best description but I was hoping it might be a known issue. Thanks Link to comment Share on other sites More sharing options...
listy Posted April 27, 2013 Share Posted April 27, 2013 Have you checked the power steering fluid? May be low, or just need changing. From what you've said, that's the first thing I'd be checking. Link to comment Share on other sites More sharing options...
adarmo Posted April 27, 2013 Author Share Posted April 27, 2013 Yes I checked everything when I bought it, it was over filled (right to the top) I just syphoned some out - I guess changing it is as good a place to start as any. I've never had a PS problem in 20yrs and 100+ cars and have never changed PS fluid so it'll be a first. Link to comment Share on other sites More sharing options...
adarmo Posted April 28, 2013 Author Share Posted April 28, 2013 Fluid hasn't helped. Is there a (replaceable) bush in the steering column ? Link to comment Share on other sites More sharing options...
Scooter Posted April 28, 2013 Share Posted April 28, 2013 (edited) I think there is, possibly two, but first try resetting it with the lever in almost the same degree of tilt as it could be the same as in this thread below... http://www.mkivsupra.net/vbb/showthread.php?244349-Steering-column-play-ratchet-loose&highlight=steering+column+play Edited April 28, 2013 by Scooter (see edit history) Link to comment Share on other sites More sharing options...
adarmo Posted April 29, 2013 Author Share Posted April 29, 2013 I have tried it in different positions if that's what you mean. I did search and saw that thread but couldn't quite understand what he meant - perhaps it's obvious once I remove the steering plastics I saw a mechanic friend today and he thinks it's just the tilt mech (although there is a small amount of play and a small noise from the rack) he thinks it's acceptable - maybe I need to try another supra. I have also seen many complain the steering is too light and mine's heavy (235/40/17 fitted, 96 facelift) I like it but I wonder if it points to a problem ? I have also noticed that the ign barrel moves approx 15mm when the steering lock is engaged - it seems to be simply clamped onto the column with the 2 anti tamper bolts. So I presume they have worked a little loose - so that's another little job - dremel the ends and replace them. The column doesn't move but I tightened up the 4 bolts anyway. Link to comment Share on other sites More sharing options...
