Mike25tt Posted April 27, 2013 Share Posted April 27, 2013 I've just fitted some oil/temp gauges and tested them. All lit up and worked fine until the second time when both gauges now don't light up and my side lights now don't work. I've gone through the fuses in the footwell and all are ok. Is there a fuse or relay for the side lights in the footwell or under the bonnet? Link to comment Share on other sites More sharing options...
Kaan W Posted April 27, 2013 Share Posted April 27, 2013 The fuse for sidelights is in the drivers footwell, have another check there should be a diagram on the inside of the lid. Link to comment Share on other sites More sharing options...
Mike25tt Posted April 27, 2013 Author Share Posted April 27, 2013 Ok cheers. I've got the diagram on the lid but unsure of which fuse is for the sidelights still! My number plate lights also don't work so it's got to be one of these! Tail 10a? Turn? Stop?! Link to comment Share on other sites More sharing options...
Kaan W Posted April 27, 2013 Share Posted April 27, 2013 Im sure its the 10amp Tail fuse Link to comment Share on other sites More sharing options...
Mike25tt Posted April 27, 2013 Author Share Posted April 27, 2013 The tail fuse is fine so maybe I've just got a loose connection since wiring the gauges in. Thanks for your help. I'm sure I will get it sorted! Link to comment Share on other sites More sharing options...
