Are Trim Clips Still Available From Toyota ?
adarmo
Guest Nicholas
They are expensive, I know! I keep buying loads!!!! It all depends how anal you are, the alternatives are just as good.
I'm as retentive as they come. I'm buying brand new Toyota parts to replace worn out parts on one heap of a 1993 T-Bar N/A MR2 at the moment. Which is only a summer run around!
The clips are OEM quality without question and likely come from the original supplier. The company on the link even list parts by Toyota part numbers to assist. Give it a go, it's cheap enough as to not matter if you don't like them.
