Andrew K Posted April 27, 2013 Share Posted April 27, 2013 Im going to be putting in a Syvecs S6GP and noticed on my engine loom near the 3 plugs that go into the Ecu that there's a Blitz speed limiter controller. My question is can I do away with this totally as the Syvecs will do this now as well or do I have to leave it in place? https://jza80.mkivsupra.net/imports/2013/04/785.jpg[/img]"] Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 27, 2013 Share Posted April 27, 2013 Definitely definitely remove it And clean up the mess left by scotchloks And, errr, what's the exposed solder work on the loom? I assume this is a work in progress..? Quote Link to comment Share on other sites More sharing options...
Andrew K Posted April 27, 2013 Author Share Posted April 27, 2013 Definitely definitely remove it And clean up the mess left by scotchloks And, errr, what's the exposed solder work on the loom? I assume this is a work in progress..? Ok thanks that's good to know the Syvec's will also sort this out ill remove it and tidy all the scotchloks marks up. The exposed solder work was from were someone had wired in another after market engine management unit, not the best work done as you can see but this isn't of my car but will be going on it once I've cleaned it all up, so yeah it's a work in progress, be starting a thread soon to what I'm doing If I remove any unwanted plugs is it just a case of cutting them off and neatly taping or getting heat shrink over the cut to protect it, or will cutting plugs off mess with the loom and cause me problems does anyone know? Quote Link to comment Share on other sites More sharing options...
