How to make my 2JZ revv higher
calebharry
  • Replies 278
Im back... Yeah, dont forget i can only talk to you guys in the night for you (now its 8:10 in the morning) were 12 hours behind so at night time (if you guys get up early) i can talk yo you guys as well! And yeah, yeah, and den, and den, i like, wuv ellis sooooo much like yeah, yeah, and den, and den, i dwibe my superera ova to da yuun, da, unnit, da united, yeah, dat, and den i cum giv ellis a biiig hug becoz i wuv ellis and all ov u giys sooooo much, and yeah, and den, chr, chris, will be my best friend in the whole wide world becoz wer da sayem age and we botf dont haev superers yeat...
Maybe Ellis paying the £10 membership fee was the wrong idea? :D
Oi... All joking and luvvy wubby aside... Actually serious...
How DO i make my 2JZ revv higher? Like, the actuall parts, ive heard that Brian Crower parts are good... What about others? And ive seen videos of Supras revving up to 10,000RPM And they sound GORGEOUS...
Lol
Being serious now, you can make your Supra rev higher
You need a modified accelerator pedal ... Unfortunately you need to modd the floor as well which is a pain . Basically the pedal goes further down .. Which makes is rev higher = going faster ....
But you need to have over 1027 BHP otherwise you won't notice the difference
It has made wonders on mine though I will give you a little tip
Don't lower your car as where you modded the floor for the pedal .. It will hit the ground
Edited by mplavery (see edit history)
Lol
You actually have to make the acellerator pedal go further down? I just thought you needed to upgrade cams pistons connecting rods and cam shaft ect. So the engine will handle going up, i thought you just put the pedal down untill the rev limiter stopps you... But with the TRD 10,000RPM revv counter allows the engine to go higher without dismantling the origional and its already all tuned and timed... Just plug in and go...
A built head is a must, Have a look at some of the traders on here like Whifbitz and SRD, They both have there own versions of build heads that have been proven on supras running 1000+bhp. The whole engine needs to be build! But the head is the thing you want to worry about the most.
Some people cut the accelerator cable shorter which is a quick fix but you need to get the right parts really
People spend loads of money changing engine parts but I find this does the trick just the same
1. Collect lots and lots of money, piles of it is best.
2. Talk to either Titan Motorsports, MVP Motorsports, Boostlogic, Garage Whifbitz, SRD
But if you want to do some research look into forged bottom ends, uprated valve trains, high lift cams, and mappable ECU's. And look further than nengun for parts, they don't actually sell that much.
