BOB B Posted April 26, 2013 Share Posted April 26, 2013 I have just removed all my air con, and before I flash everything up I wondered if there are fuses or relays I should be removing, there has to be some electrics I need to isolate. does anyone have any help or advice. Thanks, Bob. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted April 26, 2013 Share Posted April 26, 2013 I just removed pump, rad, and pipework. Dont think you really need to remove fuses Quote Link to comment Share on other sites More sharing options...
Guest kolin Posted April 27, 2013 Share Posted April 27, 2013 yes you do not need to remove the fuses just disconnect the battery if you are going to do a electric work. Quote Link to comment Share on other sites More sharing options...
antno Posted April 27, 2013 Share Posted April 27, 2013 If you auxiliary fan comes on when your engine is cold then you need to connect two wires where the ac pressure switch was. It's around the abs pump on a rhd car. I think it is wires number 2+3 but check the workshop manual. This will allow just the coolant temp switch to operate the fan. I haven't removed any relays yet so try that first. Also does anyone know if you can remove the ac amplifier with no affect to any other systems in the car? Cheers antno Quote Link to comment Share on other sites More sharing options...
BOB B Posted April 30, 2013 Author Share Posted April 30, 2013 If you auxiliary fan comes on when your engine is cold then you need to connect two wires where the ac pressure switch was. It's around the abs pump on a rhd car. I think it is wires number 2+3 but check the workshop manual. This will allow just the coolant temp switch to operate the fan. I haven't removed any relays yet so try that first. Also does anyone know if you can remove the ac amplifier with no affect to any other systems in the car? Cheers antno Thanks, yes my fan does come on and for now I have just removed the fuse, but I'll have a look and try that little jump. Quote Link to comment Share on other sites More sharing options...
antno Posted April 30, 2013 Share Posted April 30, 2013 What fuse have you removed and where is is? I have now removed the ac clutch relay. Quote Link to comment Share on other sites More sharing options...
