ashbuster Posted April 26, 2013 Share Posted April 26, 2013 any ideas where the cheapest place is to get 0 gauge wire? its for moving my battery to the boot Quote Link to comment Share on other sites More sharing options...
kjgreen3 Posted April 26, 2013 Share Posted April 26, 2013 You shouldn't need more than 5m for that. Last time I checked 0 Gauge is around 9-10 quid per metre, you may be better off buying an amplifier kit just for the 0 gauge cable. For example http://www.ebay.co.uk/itm/3000W-Complete-Amplifier-AMP-Wiring-Kit-0-Gauge-150-AMP-/250671158154?clk_rvr_id=472779333699&afsrc=1 Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 26, 2013 Share Posted April 26, 2013 Yep, I bought an amp kit just for the cable, oddly enough it works out cheaper. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 26, 2013 Author Share Posted April 26, 2013 nice one guys, i can use the 150amp fuse and holder too cant i to fue the positive cable by the battery Quote Link to comment Share on other sites More sharing options...
kjgreen3 Posted April 27, 2013 Share Posted April 27, 2013 NO, the fuse is designed for high current audio applications. Yes you will need a fuse but you will have to know what your starter motor takes when cranking over the engine and have a fuse rated for that maximum current, otherwise that 150A may pop when you try starting the supra. Maybe read up on some battery relocation threads and find out what fuse they used. But yes best to have a fuse next to the positive on the battery as if the main positive cable from the battery shorts to ground you could end up setting fire to the car. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 27, 2013 Share Posted April 27, 2013 I think David P used a 150amp fuse for his battery relocation. Best to check though. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 27, 2013 Author Share Posted April 27, 2013 yes david p used a 150 amp fuse i already checked this out. i was either going to go with the same fuse or go with a 175 amp fuse but with some 0 gauge cable on ebay i noticed some say max 150 amp which is the audio cable ones then some are over 300 amp that why im confused i thought 0 gauge were over 150 amp Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted April 27, 2013 Share Posted April 27, 2013 You shouldn't need more than 5m for that. Last time I checked 0 Gauge is around 9-10 quid per metre, you may be better off buying an amplifier kit just for the 0 gauge cable. For example http://www.ebay.co.uk/itm/3000W-Complete-Amplifier-AMP-Wiring-Kit-0-Gauge-150-AMP-/250671158154?clk_rvr_id=472779333699&afsrc=1 That's a good shout with that link right there. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 27, 2013 Author Share Posted April 27, 2013 150 amp mega fuse = * CONTINUOUS RATING: 150 AMP * BLOW RATING: 300 AMP so should handle the start up shouldnt it Quote Link to comment Share on other sites More sharing options...
