Swapping Fibreglass Nosecone Back To Std - What Bits Will I Need ?
adarmo
Hi,
My Supra currently has a Veilside nosecone on it and I want to swap it back to OEM.
I have an OEM nosecone but before I remove the veilside I wondered if anyone could tell me if I'm likely to need any other parts as I'd like to do it in one go rather than have the car off the road.
If anyone has any pics so I can see what should be there that would be great.
I'm thinking bumper reinforcing strips, plastic ducting any special fixings etc
Thanks
There should be a metal strip either side where the bumper attaches to the wing.
There should be a polystyrene insert in the oem front bumper.
You should have a crash bar (sometimes removed when an aftermarket front is fitted)
There should also be an oem undertray iirc.
I think that's it. Someone else will add if there is anything more.
Had a good look today.
What fits around the mouth / rad intake of the bumper ?
Mine has holes top and bottom and nothing to fit to.
Is all that holds the bumper on the two side strips and the top strip by the rad ?
Doesn't seem much
Doesn't seem much
Yep. That's it mate. Not sure what the holes in the mouth of the bumper are for. Possibly custom number plate brackets at some point.
