Iky Posted November 27, 2013 Share Posted November 27, 2013 Can't wait to see the car with its new paint on dude Me neither, i watched a program on discovery the other day about the Aventador. They were talking about how the paint is special in how the different layers work to produce the colour. Can't remember the exact details as I've slept since then! Link to comment Share on other sites More sharing options...
markssupra Posted November 27, 2013 Author Share Posted November 27, 2013 Can't wait to see the car with its new paint on dude Me neither, i watched a program on discovery the other day about the Aventador. They were talking about how the paint is special in how the different layers work to produce the colour. Can't remember the exact details as I've slept since then! Wont be long, Rob has received the paint now Spoke to him today and will hopefully go to Robs workshop within the next week or so to have a look at the colour. Link to comment Share on other sites More sharing options...
Kaan W Posted November 27, 2013 Share Posted November 27, 2013 Wont be long, Rob has received the paint now Spoke to him today and will hopefully go to Robs workshop within the next week or so to have a look at the colour. Exciting times I actually cant wait to see this lovely colour on a supra! Link to comment Share on other sites More sharing options...
Philly_1 Lex Posted November 27, 2013 Share Posted November 27, 2013 Mark Just let me know when I can schedule my car with you.... lol. See you soon mate. Link to comment Share on other sites More sharing options...
markssupra Posted November 27, 2013 Author Share Posted November 27, 2013 (edited) Mark Just let me know when I can schedule my car with you.... lol. See you soon mate. Lol, I might be able to squeeze you in sometime next year I had a siezed bolt in one of lower arms which had to be drilled out. The bolt was one of a pair that holds the shock absorber bracket to the lower arm. After carefully drilling the bolt out a small amount of bolt thread remained in the arm although this was now loose enough to be screwed out by hand. I then run an M10 x 1.25 tap through all the threads to make sure the threads were clear. Shock absorber bracket, powder coated and ready to bolt back on to the lower arm. Bracket bolted back on to the lower arm with nice new shiny bolts and bushes installed. New lower arm camber adjust bolts waiting to be installed. Damn those labels are a pita to get off, quickest way was to soak in hot soapy water for a few minutes so they peel off. One of the Lower arm support braces powder coated. Upper and lower arms installed, wheel hub mounted on with new castle nuts, cotter pins and clips for the ball joints. Edited November 28, 2013 by markssupra (see edit history) Link to comment Share on other sites More sharing options...
clay Posted November 27, 2013 Share Posted November 27, 2013 looking good mate. Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 (edited) Rear steel section of the subframe, powdercoated black and installed. Power steering rack cleaned, checked over and painted. All ps fluid pipework cleaned through. Forgot to order some new tie rod ball joint nuts and clips with all the other bits, so ordered today! Edited November 28, 2013 by markssupra (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted November 28, 2013 Share Posted November 28, 2013 Wow. Amazing. - - - Updated - - - Wow. Amazing. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2013 Share Posted November 28, 2013 Appreciate the worksmanship. However I wouldn't fit polybushes on a Supra. Quite a few people on here have found it degrades the ride too much for a road car. Hence the expensive purchase of all new toyota, rubber bushed arms. Hopefully it rides acceptably for you, after having gone to the trouble. Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 Appreciate the worksmanship. However I wouldn't fit polybushes on a Supra. Quite a few people on here have found it degrades the ride too much for a road car. Hence the expensive purchase of all new toyota, rubber bushed arms. Hopefully it rides acceptably for you, after having gone to the trouble. I know polybushes aren't the best solution James, but after replacing the rubber bushes with R2's on the rear suspension a few years ago it tightened the rear end up and I found the ride acceptable even with Eibachs. Its a cheaper solution to get the car back on the road and after doing all this work, will be easy to replace with OEM if I need to Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2013 Share Posted November 28, 2013 I know polybushes aren't the best solution James, but after replacing the rubber bushes with R2's on the rear suspension a few years ago it tightened the rear end up and I found the ride acceptable even with Eibachs. Its a cheaper solution to get the car back on the road and after doing all this work, will be easy to replace with OEM if I need to If you run springs on the softer side, and seeing as it's an aerotop, the extra chassis compliance means you may well get away with it. Please don't think I'm knocking it, it's a great project. Maybe also leave the stock spherical bearings in the upper rear arms? P.S. Give Mitchell a kick up the arse and tell him to hurry up. Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 (edited) If you run springs on the softer side, and seeing as it's an aerotop, the extra chassis compliance means you may well get away with it. Please don't think I'm knocking it, it's a great project. Maybe also leave the stock spherical bearings in the upper rear arms? P.S. Give Mitchell a kick up the arse and tell him to hurry up. Oi!! Aero's aren't that bad. No worries mate, all opinions are welcome and I know what your saying. As you know, these cars just suck money out of you quicker than the Government! Robs doing allright, you leave him alone, he's letting the primer go off for week before putting any colour on Edited November 28, 2013 by markssupra (see edit history) Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 Latest pics from Rob! All 3 stages on. That is just so damn sexy cant wait to see it for real I'll be scared to drive it. Anyone got any ideas of what can I wrap it in to protect it during the rebuild? Link to comment Share on other sites More sharing options...
Kaan W Posted November 28, 2013 Share Posted November 28, 2013 Yesss!!! Look at that colour Link to comment Share on other sites More sharing options...
Fitz Posted November 28, 2013 Share Posted November 28, 2013 I bet in the Summer when the sun hits it, panties will drop Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2013 Share Posted November 28, 2013 I bet in the Summer when the sun hits it, panties will drop Maybe yours Fitz!! Link to comment Share on other sites More sharing options...
drift_bear Posted November 28, 2013 Share Posted November 28, 2013 I seen these on Facebook! Looks stunning mark. I would suggest use pallet wrap or something like SRD use? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 28, 2013 Share Posted November 28, 2013 I suggest dust a soft dust sheet! be very careful mate... ideally you dont want anything. glad you like, stay tuned for engine bay and body shuts tomorrow Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2013 Share Posted November 28, 2013 A greddy intake would look lovely on this car.... Link to comment Share on other sites More sharing options...
drift_bear Posted November 28, 2013 Share Posted November 28, 2013 a greddy intake would look lovely on this car.... Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 A greddy intake would look lovely on this car.... I hope a Veilside intake will look good too Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2013 Share Posted November 28, 2013 I hope a Veilside intake will look good too Drat!! Forgot you had that. Very lag inducing...... Link to comment Share on other sites More sharing options...
Dim Sum Posted November 28, 2013 Share Posted November 28, 2013 Looking good. 100% going to stand out with the colour choice. Great stuff Link to comment Share on other sites More sharing options...
markssupra Posted November 28, 2013 Author Share Posted November 28, 2013 Drat!! Forgot you had that. Very lag inducing...... Lol. Yesss!!! Look at that colour I bet in the Summer when the sun hits it, panties will drop Maybe yours Fitz!! I seen these on Facebook! Looks stunning mark. I would suggest use pallet wrap or something like SRD use? I suggest dust a soft dust sheet! be very careful mate... ideally you dont want anything. glad you like, stay tuned for engine bay and body shuts tomorrow Thanks all, comments very much appreciated. Out of all the colours I could have chosen I am so glad I picked this. Rob has created another stunning paint job, thanks mate, cant wait to see the body and bay. Better get my finger out and get the car finished. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 29, 2013 Share Posted November 29, 2013 Bay will really show the colour mate! what we done yesterday look very orange in pics, due to the items having no nice curves. Glad you chose a unusal colour its a pleasure to be doing it for you. More pics on facebook. Members who are not following then subscribe to 'Darnley auto works' facebook page. Link to comment Share on other sites More sharing options...
