markssupra Posted April 25, 2013 Share Posted April 25, 2013 (edited) Thought it was about time to start the build thread as I have quite a collection of parts now and work on the car is progressing well. Didn't realise how long it takes to write these project threads, just about have enough time between work and sleeping to actually work on the car. After seeing some amazing builds from Wayne (supradibbs), Rob's Gold Rush, Hodge, Steve m's, Jays at SRD, SupraGold and many more, I was inspired to try as it's always been something I have wanted to do. I hope I can achieve the same quality as you guys have. Owned the car for over 8 years now and was a stock Twin Turbo Aerotop with 52000 miles when I bought it. The car has been BPU for a few years now and was happy with it until I saw RobD was selling a complete HKS GT2835 twin kit. I have always wanted big twins since seeing them on another members car, not long after I first bought my mine. I bought the kit July last year, these had been recently refurbished by Owen Developments and were just what I had been looking for. When I found out Lee P was also breaking his big twins setup, I had another opportunity to buy more parts for my build. I hope to do most of the work on the car myself, and being my first, will be taking lots of pics and time to make notes along the way. Not sure of a time scale yet but hope to be finished in about 12 to 18 months time. I started stripping the car December last year so have some catching up to do on this build thread. So far the engine is out, stripped, cleaned and sent for machining work plus a few other bits I will update as the thread progresses. I had been looking at various forged engine specs and with advice from Lee at SRD, Paul Whiffin and my engine machinist, arrived at the following engine spec. Big thank you to Lee at SRD, Paul Whiffin, Rob Mitchell and Steve M for all your advice so far, plenty will be more needed guys I am sure there are parts missing from the list so will update it as I go along. I have most of the parts listed and always open to opinions/advice. Engine: 8200 rpm rev limit Mahle Pistons 86.5mm Brian Crower BC625+ con rods inc ARP fasteners ACL Race Bearings Titan Billet Main Caps Fully balanced internals and polished crank Stock crankshaft Welded crank sprocket ARP Main Studs L19 ARP Head Stud Kit New stock water pump New stock oil pump Toyota complete gasket set Toyota stock head gasket HKS timing belt Billet tensioner and idler pulley Titan adjustable cam pulleys Whifbitz 72 degree thermostat SRD Custom Breather System Blitz Oil Cooler PWR Radiator Twin kenlowe Electric Fans Titan crank pulley TRD engine mounts Stage 5 SRD Ported & Polished Head with: Ferrea Manganese Bronze Valve Guides Ferrea 1mm Oversized Competition Plus valves Ferrea Valve Seals Ferrea Dual Valve Springs Ferrea Titanium Retainers Ferrea Spring Seat Locators Ferrea Valve Locks SRD stage 3 - 280° 10.2mm lift Cams Turbocharger & Induction: HKS Twin GT2835 Turbo Kit,Water cooled Turbo Spec 52t, .73 AR Hot, .50 AR cold - Rebuilt by Owen Developments Twin HKS heatshields Twin HKS 50mm racing wastgates SRD Custom Intercooler Twin HKS SSQV Dump Valves Veilside Plenum Veilside 100mm Throttle Body Fuel, Tuning and ECU: Twin Walbro Intank Pumps Titan triple Fuel Pump Hanger HKS 1000cc Injectors HKS Fuel Pressure Regulator Paxton High Flow Fuel Filter SRD Custom Fuel Lines Veilside Fuel Rail 3.5 Bar Map Sensor Syvecs S6 ECU Exhaust: 4" HKS Titanium Drive train. Stock autobox Stock torque converter Twin SRD transmission coolers Suspension, Wheels, Tires & Brakes: KW Variant 3 inox-line – Perfect Street Performance 8pot 356mm Ksport front big brake kit 4pot 356mm Ksport rear big brake kit CCW LM20's 3 piece, Front 10j with 265/35/18 Michelin Pilots. Rear 11.5j with 315/30/18 Michelin Pilots Interior: New Heater matrix Exterior: Colour: Lamborghini Arancio Argos Stock body withMVP Motorsports Front Lip RMM (Rod Millen Motorsports) MKIV Supra Wing with Carbon Fiber Center Zunsport front grille set Facelift rear lights Facelift front indicators Clear side repeaters Car as it has been for about 5-6 years. Edited July 19, 2019 by markssupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Justin Bieber Posted April 25, 2013 Share Posted April 25, 2013 This is going to be awesome! Gone off the widebody idea then mate?? Quote Link to comment Share on other sites More sharing options...
markssupra Posted April 25, 2013 Author Share Posted April 25, 2013 (edited) Yes mate, got fed up with the Doluck finding small bumps and kerbs, so thought to myself, why am I thinking about adding more fibreglass to the car. Talked myself out of it. Edited April 25, 2013 by markssupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Abz Posted April 25, 2013 Share Posted April 25, 2013 Been wondering when this thread would pop up! An their was me thinking you are just having an engine overhaul Stock with huge tyres will look awesome!! Looking forward to seeing this come together. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted April 25, 2013 Share Posted April 25, 2013 Awesome spec ....!!! Quote Link to comment Share on other sites More sharing options...
markssupra Posted April 25, 2013 Author Share Posted April 25, 2013 Been wondering when this thread would pop up! An their was me thinking you are just having an engine overhaul Stock with huge tyres will look awesome!! Looking forward to seeing this come together. Thanks mate, thats the look I hope to achieve. Quote Link to comment Share on other sites More sharing options...
DaveR Posted April 26, 2013 Share Posted April 26, 2013 Good stuff. I'm gonna Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 26, 2013 Share Posted April 26, 2013 Another epic build, good luck with the rest of the build Quote Link to comment Share on other sites More sharing options...
Brazil Posted April 26, 2013 Share Posted April 26, 2013 Another epic amount of $$ to be spent..! LOL sorry I am just having a laugh because I've just gone through it including body restorations with suspension overhaul and seeing a new build thread popping up it flashes back the amount of $$ it has costed me..! ILMAO... We are a bunch of Nuts on here..! Good luck with the project... look forwards to the updates...! by the looks of it you have a solid plan to work on...! Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 26, 2013 Share Posted April 26, 2013 You sly bas.. mark Can't wait to see the updates and the finished result mate What power are you aiming for? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 26, 2013 Share Posted April 26, 2013 Wow. Awesome spec. Good luck P.S. I would go for bigger injectors. Quote Link to comment Share on other sites More sharing options...
Lee P Posted April 26, 2013 Share Posted April 26, 2013 Looking forward to this build, good to see bits of my car being put to good use Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted April 26, 2013 Share Posted April 26, 2013 Looking forward to reading the updates Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 26, 2013 Share Posted April 26, 2013 Looking forward to this build, good to see bits of my car being put to good use Is that your head Lee? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 26, 2013 Share Posted April 26, 2013 This will be brilliant, I'm looking forward to more updates and pics. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 26, 2013 Share Posted April 26, 2013 Going to be awesome! always a PM away mate and always happy to help. Quote Link to comment Share on other sites More sharing options...
tony tt Posted April 26, 2013 Share Posted April 26, 2013 Good luck with it Mark sounds like it will be a beautiful car when it's finished. Quote Link to comment Share on other sites More sharing options...
James Posted April 26, 2013 Share Posted April 26, 2013 Facelift headlights too This sounds like it is going to be excellent Stage 5 head?! The same as Jay's? Quote Link to comment Share on other sites More sharing options...
Lee P Posted April 26, 2013 Share Posted April 26, 2013 Is that your head Lee? It is my head yes, refreshed though. Same spec as Jay's Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 26, 2013 Share Posted April 26, 2013 (edited) Nice to see its staying Auto too! Im really impressed with how my setup drives but you have alot of advantages over my spec, so its going to be even better!! Seriously consider the boostlogic exhaust mine sounds insane lol, sounds the business even at idle. Go bigger front brakes Edited April 26, 2013 by Rob_Mitchell (see edit history) Quote Link to comment Share on other sites More sharing options...
markssupra Posted April 26, 2013 Author Share Posted April 26, 2013 (edited) Another epic amount of $$ to be spent..! LOL sorry I am just having a laugh because I've just gone through it including body restorations with suspension overhaul and seeing a new build thread popping up it flashes back the amount of $$ it has costed me..! ILMAO... We are a bunch of Nuts on here..! Good luck with the project... look forwards to the updates...! by the looks of it you have a solid plan to work on...! I must admit that as I got deeper with buying parts, the strip down and selling off parts, I used to wake up in a cold sweat thinking what the hell am I doing, dont tell the missus though Thank you, taken me a while to get sorted with what I want, buying the turbo's first sealed it. You sly bas.. mark Can't wait to see the updates and the finished result mate What power are you aiming for? Thanks Alex, excited about doing this project. Not going to rush it either, hopefully this time next year if it goes to plan. Lee was running 970hp 738ftlbs, 825hp & 627ftlbs at the wheels, if I could get somewhere near to that I would be very happy and extremely scared Wow. Awesome spec. Good luck P.S. I would go for bigger injectors. Thank you, hopefully be big enough as I got the whole fuel setup from Lee, happy to be advised otherwise though. Looking forward to this build, good to see bits of my car being put to good use Thanks Lee, would have had the whole lot if I hadn't already got the turbo's, you have been a star with all your advice. Plenty more will be needed Going to be awesome! always a PM away mate and always happy to help. Thanks mate, well appreciated. Good luck with it Mark sounds like it will be a beautiful car when it's finished. Thanks Tony, now the suns shining I am missing her big time, but will be worth the wait. Facelift headlights too This sounds like it is going to be excellent Stage 5 head?! The same as Jay's? Stop it!!! The parts list just gets longer and longer Yep, stage 5 head that was Lee's. Nice to see its staying Auto too! Im really impressed with how my setup drives but you have alot of advantages over my spec, so its going to be even better!! Seriously consider the boostlogic exhaust mine sounds insane lol, sounds the business even at idle. Go bigger front brakes Yeah, thought about going manual but it would have just bumped up the cost so much, I need a ride in yours to feel the awesomeness Will have a listen to yours mate. Will we be known as The Big twins twins Thanks everyone for the kind comments. I wouldn't be doing the car if not for this club's members willing to give so much advice and help. Edited April 26, 2013 by markssupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Brazil Posted April 26, 2013 Share Posted April 26, 2013 The hardest part is when the project get hold up you are just buying parts without seeing any progress...! Months will roll by and you start to miss having a sports car and wonder why the hell did I em-barque on this crusade in the first place..! But at the end good things come for those who waits... and the reward is something truly special and super car performance..! Quote Link to comment Share on other sites More sharing options...
markssupra Posted April 26, 2013 Author Share Posted April 26, 2013 Decided on the colour, Lamborgini Arancio Argos. Seen one of these up close in this colour and it was fantastic, pearl effect. Quote Link to comment Share on other sites More sharing options...
markssupra Posted April 26, 2013 Author Share Posted April 26, 2013 The hardest part is when the project get hold up you are just buying parts without seeing any progress...! Months will roll by and you start to miss having a sports car and wonder why the hell did I em-barque on this crusade in the first place..! But at the end good things come for those who waits... and the reward is something truly special and super car performance..! Tell me about it, spent loads so far and still loads to spend and all I have is a shell, a growing pile of parts and a shed load of work. It will all be worth it. Quote Link to comment Share on other sites More sharing options...
Brazil Posted April 26, 2013 Share Posted April 26, 2013 If you like that colour have a look at Renault's new Flame Red it looks amazing candy like in real life..! http://www.caricos.com/cars/r/renault/2013_renault_clio/1024x768/2.html Quote Link to comment Share on other sites More sharing options...
