Caesard Posted April 24, 2013 Share Posted April 24, 2013 I am going to be spraying my front bumper. It is still in gel coat, and I don't want the paint flaking anytime later. What is the best primer to use to spray the bumper before block sanding it. Anything I can get on Fleabay? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 24, 2013 Share Posted April 24, 2013 Std 2K primer will be fine, provided you prep the gel coat first, IE spirit wipe and flat with 280 grit. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 24, 2013 Share Posted April 24, 2013 ^^^ as above, std 2pack primer, i used 2pk wash primer when i painted my supra last time which i found easier to use compared to primer i had used in tge past Quote Link to comment Share on other sites More sharing options...
Caesard Posted April 24, 2013 Author Share Posted April 24, 2013 Thanks fellas. Will post up a build thread when done. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2013 Share Posted April 25, 2013 Ask a body shop dealing mainly in fibreglass cars, there are specialist primers available. You may gain some life by using a plasticiser in the paint to keep it from cracking. Lotus and TVR specialists would be good sources of info. Quote Link to comment Share on other sites More sharing options...
