GRIM Posted April 23, 2013 Share Posted April 23, 2013 Hi guys can anyone tell me how can I check an "integration relay" my key ring light doesn't work neither does the foot light I have checked the fuses and they are ok dome light works I have searched the threads and it seems that an integration relay is my problem but want to be sure before I buy that thing Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 24, 2013 Share Posted April 24, 2013 I'll have a look through the wiring diagram if I get chance tomorrow for you. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 24, 2013 Share Posted April 24, 2013 (edited) Looking at the wiring diagram, the dome fuse provides 12 volts to both the integration relay and the ignition barrel LED, and the integration relay provides the negative when required. It appears as though the same negative is used to trigger the personal light (interior light). If you are saying the interior lights work as far as I can see, the integration relay is working correctly. If the footlights (LED's) are OEM they will most probably be wired from the ignition barrel connector. It might be worth checking this connector just under the steering column (my money is on a loose connection). Hope this is of some use to you. Edited April 24, 2013 by Kev.O (see edit history) Quote Link to comment Share on other sites More sharing options...
GRIM Posted April 25, 2013 Author Share Posted April 25, 2013 that's def-ly helpful thanks yes sir, the footwell light is wired from the ignition barell connector and has its own 1A fuse there was a small 1A fuse under the steering column just for the footwell lights which was burnt (that day, ignition barrel led worked, just no footwell light) I replaced the fuse with the same type 1A fuse, after that everything worked but in about 5 second the ignition barrel as well as footwell lights turned off, that small 1A fuse was OK there're also no lose connections as I took everything apart all the fuses are ok I don't know what else I can check Dome(interior) lights still work Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 25, 2013 Share Posted April 25, 2013 How about removing the connection for the footwell lights, thus back to stock wiring? Quote Link to comment Share on other sites More sharing options...
GRIM Posted April 25, 2013 Author Share Posted April 25, 2013 the footwell lights are OEM I tried to disconnect it but it was too late I think there was a short somewhere in the footwell harness I'm removing and making a new harness for the footwell lights anyway but ignition barrel still doesn't work Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 25, 2013 Share Posted April 25, 2013 The footwell lights use a male and female OEM connector so can be easily disconnected. Are you able to check the voltage with a meter? As far as I can see if the interior lights are working on the door switches then the integration relay is working so the issue must be between the relay and the ignition barrel LED. Quote Link to comment Share on other sites More sharing options...
GRIM Posted April 25, 2013 Author Share Posted April 25, 2013 thanks for the replies sir yes, I've seen those white oem connectors I'll check the voltage tomorrow and will reply with results and some pictures also will try to follow the wires to see maybe there's a fuse somewhere (but from what I remember, when I looked for the fuse last time the red power wire was going to the engine bay) do you know if there're any more fuses? as I understand that integration relay gives a ground! and the power is constant, right? Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 26, 2013 Share Posted April 26, 2013 Yes correct a constant positive and switched negative. I'm not sure why there is a wire going to the engine bay. I recently removed an OEM footwell loom and it simply just connected into the white connector and had an inline fuse. It might be that at some point someone decided to use the power from else where. If the footwell lights are just LEDs I can't see the extra power causing an issue and would use the ignition barrel power. The dash wiring plugs into the drivers side fuse board and goes direct to the steering column. Yes a few pictures might help. Good luck. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted May 8, 2013 Share Posted May 8, 2013 How did you get on GRIM? Quote Link to comment Share on other sites More sharing options...
