james_cbr Posted April 23, 2013 Share Posted April 23, 2013 (edited) ok got 2jz gte from abz / spg was told has leak so thort would be ok cuple seels maby split sump and reseal but the more i strip off ot the more i think do i just strip it completly and rebuild from ground up ? pics so far of rear oil leaak looks like cam covers and rear crank seel took inlet bits off to get a nice close look at hybreed turbos but 1st turbo looks oiley not good for turbos rebuilt 6k ago striped back a bit further turbo 2 looks beter inside bit of oil running down from cam seels and oil pump looks oiley as well dosent look so bad in pics oiley down side closer pic going to replave ribed pipes from inlet with silicon joiners last pic of how far ive gone look inlet off as i intend to paint with engine enamal how far do i go ? Edited April 23, 2013 by james_cbr (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 23, 2013 Share Posted April 23, 2013 Depends on your goals, but I would start with replacing all the gaskets and seals. Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 23, 2013 Author Share Posted April 23, 2013 well with curent limited funds im looking to do big end and main bering set full gasget set regrined valves do valve stem oil seels new oil pump trying to save up for these atm want a nice reliable engine with no leaks that i can turn the power up on and slowly mod it as i get use to more power Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 23, 2013 Author Share Posted April 23, 2013 also change all vacum lines and odd bits of hose for silicon so no boost issues Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 23, 2013 Share Posted April 23, 2013 Its hard to say really, just replace the pumps, gaskets and do stem seals and that will be good for 600hp. The if you want more go for a full a built block, bigger cams etc then go from there. But its a bit pointless doing all this first if you dont plan on going for big power. Quote Link to comment Share on other sites More sharing options...
Abz Posted April 23, 2013 Share Posted April 23, 2013 It all depends on your budget James, also on future plans? Replacement seals & a clean up would be ideal & nice and easy, I'll chase up with SPG with regards to the seals. Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 23, 2013 Author Share Posted April 23, 2013 yeh gonna go to the 600 700 mark over time dont wanna spend loads in 1 go and have huge power and not be able to drive it im going to slowly mod more power over time so i get ust to how the car goes just want evrything to be reliable and long lasting sort out leaks and botom end and top end now then its just bolt on bits later on like ecu cams injecters and so on Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2013 Share Posted April 25, 2013 I would say that was leaking from pretty much every orifice Worse ones to fix are worn cranks causing front or rear main bearing seal leakage, and middle sump casting to block leaking, but if you are having the crank out to check and change shells you should be able to fix that in the process. I rarely see a MKIV head that doesn't need guides and some valves these days. The power is in the head, and piston sealing, so do it right, which will be expensive. Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 25, 2013 Author Share Posted April 25, 2013 yes im a therm belever of do it right do it once hence going to these lengts on the rebuild Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 25, 2013 Share Posted April 25, 2013 makes you think seeing someone elses engine out and the state its in, what your own looks like, what milegae is on it? Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 25, 2013 Author Share Posted April 25, 2013 80k miles Quote Link to comment Share on other sites More sharing options...
james_cbr Posted April 25, 2013 Author Share Posted April 25, 2013 ok todays update on the strip defantly cam seals leaking turbos off now im suck at as much as i can do till the engine stand becomes free next step whail i wate cleaning painting and polishing other bits allready off Quote Link to comment Share on other sites More sharing options...
james_cbr Posted May 5, 2013 Author Share Posted May 5, 2013 ok whal im wateing to get in to it a bit more i decided to do some cleaning and painting then after a bit of sanding and started the other then bothy were closer to how i want them got wire brush out and cleaned down my boost/inlet pipes and started painting some hanging bit where ever i could Quote Link to comment Share on other sites More sharing options...
james_cbr Posted July 3, 2015 Author Share Posted July 3, 2015 forgot about updating this hears the latest heads off and everything cleaned Quote Link to comment Share on other sites More sharing options...
james_cbr Posted July 3, 2015 Author Share Posted July 3, 2015 head cleaned ready to work with test fitting new parts bit of polishing Quote Link to comment Share on other sites More sharing options...
james_cbr Posted July 3, 2015 Author Share Posted July 3, 2015 (edited) more cleaning shiny goodies and a quick mock up Edited July 4, 2015 by james_cbr (see edit history) Quote Link to comment Share on other sites More sharing options...
james_cbr Posted July 4, 2015 Author Share Posted July 4, 2015 (edited) Just been to srd and picked up some shineys Edited July 4, 2015 by james_cbr (see edit history) Quote Link to comment Share on other sites More sharing options...
MRX Posted July 4, 2015 Share Posted July 4, 2015 Amazing work mate, looks awesome! Quote Link to comment Share on other sites More sharing options...
james_cbr Posted September 5, 2015 Author Share Posted September 5, 2015 well I guess its time to update this ive picked it up from srd and got building and now its in the car hehe this is the lovly work srd did for me then I picked it up got back to my work shop and got cracking Quote Link to comment Share on other sites More sharing options...
james_cbr Posted September 5, 2015 Author Share Posted September 5, 2015 got cracking with new bits and shineys Quote Link to comment Share on other sites More sharing options...
james_cbr Posted September 5, 2015 Author Share Posted September 5, 2015 then you end up with this Quote Link to comment Share on other sites More sharing options...
james_cbr Posted September 5, 2015 Author Share Posted September 5, 2015 (edited) o and a first start vid Edited September 5, 2015 by james_cbr (see edit history) Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 5, 2015 Share Posted September 5, 2015 Here you go Quote Link to comment Share on other sites More sharing options...
james_cbr Posted September 5, 2015 Author Share Posted September 5, 2015 Thanks I'm good with pics but never seem to be able to do vids Quote Link to comment Share on other sites More sharing options...
