Removing Rear Arm (Lower No.2)
Josh42
So, this is what happened to my Rear Lower No.2 Arm[ATTACH]168124[/ATTACH]
I've tried removing it, and I've managed to undo the bolt that holds it to the strut, the nut on the end of the ball joint and the nut holding it onto the subframe.
I can't however remove the bolt holding it onto the subframe from its position.
This is the one I'm talking aboutImageUploadedByTapatalk1366738870.247817.jpg
Anyone got any suggestions?
Thanks
Josh
I was doing these on the shell I was scrapping, passenger side flew out but the drivers side was a whole pile of *^#t!! Even after soaking over 2nights in WD40 a 9x rivet gun on the bolt and rivet block on the back of the arm and it STILL wouldn't budge....... I didn't want it off after tht lol
I don't blame you mate!
Wish I had the option:(
If I had to I would either carefully cut the bolt head and threaded section off or even a nice heavy duty G clamp, put a large socket over the bolt head the put the g clamp over the socket and bolt tail and try 'pressing' it out
As for grinding, I'm a little worried about doing it but feared that may be the case.
Excuse the poor drawing, but I'm going to manufacture something like this:
Which should act like a pulley draw to "push" the bolt out...[ATTACH]168137[/ATTACH]
Why don't you try my G clamp suggestion? Same principal and much simpler?
Good luck Josh
Been there and tried just about everything when i did mine.
Big diameter cutting disc is the way to go then replace the arm and bolt.
The bush in the arm will be scrap anyway so a new arm is the way forward
