help - 2 beeps followed by 'limp mode'?
leeg
heard two beeps the other night then later on that night floored it through some lights but then had to slam the brakes on, thn coming off of the roundabout the car had little/no acceleration, like it went in to limp mode or something? no the car drives fine until it is properly warmed up then the same thing happens. limp mode. does anyone know or had this happen to them? does the beeps even mean anything? help help help
Edited by James (see edit history)
for the roundabout lol
For anyone you could have ended up the hoop of :rolleyes:
Why do people seem to think we are impressed by the speeds they can drive at on the road? If you have to "slam your brakes on" you are simply driving too fast for the environment you are in.
Strange, what modifications have been done?
none really, just the air filter and exhaust system, but nothing that is new and I have had the car for three years. the only difference when it went into limp mode the second time, I had then warning light and engine light come on? but with same issues. when I put it to neutal it revs to 1000?
not trying to impress, trying to explain what may have caused the fault, ie sharp braking possibly knocked something loose?
- - - Updated - - -
possibly exaggerated slamming brakes on but had to brake more than I thought I would need to
Low oil? This happened to me under hard braking as all the oil gets thrown to the front of the engine. But im not sure how the stock ecu reacts to low oil etc. But might be worth checking...
thanks for the advice the oil was fairly low and have topped up since but haven't driven incase same thing happened. cheers
no oil light came on at all, but, is it possible those two beeps could have ment something?
Like I said I have no idea about the stock ecu and its functions but I guess the two beeps must mean somethings not right. If the oil was low and this has happened after slamming the brakes on it must be this. Find a test track try the same thing and see if it happens again :)
I've edited the thread title to something a little more descriptive, both to aid in letting you find out what is causing the issue but also for future search references if required :)
cheers for that. appreciated
no its all stock other than the filter and exhaust, like any I suppose. what kaan said me mean something. but do you know if the ecu assuming, would beep for low oil? possibility. topped up with oil earlier so will try tomorrow I think.
As I said, never heard of a stock supra beeping before, unless you leave the keys in the ignition.
have you plugged a diagnostic tool in before? the strange thing is I plugged on in today, it made the same beep? but couldn't recognise the car? really odd
why so moody? ment for you not swampy
With other recent threads regarding ill considered driving techniques, wrong driving style for conditions etc, plus the fact I got some bad news today, I'm not in the best of moods. You just happened to be an outlet for a moment, and I do apologise :innocent:
Could be worse, my wife has had to deal with me (a 26 year old) doing a very good impression of a grumpy old man all evening ;)
yeah look no worries mate, I should have worded it a bit better really, sorry to hear about the bad news, n oneed for apologies :)
