Is this taking TLC for your engine too far?
BOB B
Thought I would get up close and very personal with my engine, then her indoors came running out with the camera.
I'm just in the process of doing quite a few jobs in preparation for Dragonball, and while I had all the front of the bay out I found it much easier to work on the engine by climbing in, great if you a stump like me, don't know if it would work if you were six foot twenty
Edited by BOB B (see edit history)
I've been stuck in there for three days now,and it's now sending out ransom notes.
I have the radiator out to remove all the air con stuff, it hasn't worked for years now and I don't miss it, also fitting a CW refurbished power steering pump, doing both belts, new plugs, new rocker cover gaskets, repainting/repollishing a lot of bits, new rear OEM discs, refitting the second Cat ready for MOT in two weeks, then its the mega clean, top to bottom, and inside to out.
I'll be too worn out to go on't Dragonball.
haha :D i also have the air con stuff out, can you give me some tips to remove air con compressor also, can you add 2-3 photos? Thanks:cool:
