Innovate LC-1 with a Syvecs
bigbloodyturbo
Has anyone got an LC-1 feeding a 0-5v wideband signal to one of the analogue inputs of a syvecs?
I have this and it worked fine for about 30mins of tinkering but since then it now reads circa 2 afr rich. The software says its seeing approx 1volt lower than I know its getting so it's saying i'm at 7-8afr when i'm idling at 10. When sticking a meter on the input of the syvecs I'm getting 1volt to ground. When I have the LC-1 analogue output hooked up to the syvecs i have the LC-1 grounded to chassis (heater and system ground).
I have tried grounding system ground from the LC-1 to the ABS/sensor ground on the syvecs but it has not made any difference, it still reads 1volt lower than I know the LC-1 is feeding it. Should I try a unipolar input or does the 0-5v analogue input have a pull up, seems strange for it to pull up 1 volt?
just incase anyone has a similar issue this turned out to be a ground offset issue with the Syvecs. Grounded the Syvecs power ground to chassis and everything is now working. Also wasn't helped by the LC-1 analogue ground not actually grounding anything but now all working with the LC-1 system and heater ground grounded together. Leason learned, check one's grounds:innocent:
