Bigger injector stock rail
JMB
Guest stp88
you well only need to change injectors when you have max them out , you are still using the stock ecu so you well not reach there until you have done some other upgrades .
You MUST keep stock flow rate injectors with the stock ecu. Bigger injectors need a mappable ecu. The stock injectors can keep up with all the air flow the stock turbos are capable of.
Your English is very good, but you meant WOndering, not WAndering. To wander is to stray. To wonder is to muse. English is an awful language :)
