Rd legal drag supra - Project Zoran!
Marco79
  • Replies 181
Posted Images
  • 2 weeks later...
  • 3 weeks later...
Ended up at the unit earlier and got a few little jobs done :)
Fitted the turbo housing now 25mm shorter, very kindly welded by PJavon :D it now fits a treat!!
This also meant I could final fit my oil return line :) Then fabricated a mount for the dash2, will make a dashboard cowling next to make it look sweet :)
Worked out the intercooler piping aswell, will need to source 3 x 90 degree, 1 x 45 degree and a straight length (4" diameter)
  • 4 weeks later...
  • 2 weeks later...
Awsome dude! Can you not get an -an extention dude like -an 12 male end at one end and a female at the other end or would that still hit?
Good shout mate but think it will still hit, might stand a chance with a fitting that screws direct into the rail without the union and a more acute angle but haven't found anything like that yet :(
  • 1 month later...
  • 2 weeks later...
  • 1 month later...
Guest Nicholas
Looks great, can't the return feed be moved to the bottom of the rail? if not just get the breather welded up and moved. Will look much cleaner than using a banjo fitting.
  • 1 month later...
Connected the fuse box (located in passenger footwell) upto the battery in the boot via the scuttle mounted shutoff switch and installed a 10 micron fuel filter in the post pump supply line :). Received my custom made carbon fibre Zoran badge which looks the nuts :D
