Marco79 Posted May 4, 2013 Author Share Posted May 4, 2013 Quality exhaust Mark, loving the custom loom. Have u got any pics u can post of making these mate? Let the creator show off his handy work Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 About 6 months ago, Mark asked me to strip out some of the unwanted wiring from all the car looms which started off as a small job lasting about a month . I managed to use all OEM connectors and pins as well as relocate the main fusebox and remove the drivers side fuse box and integration relay. Mark also wanted to use a syvecs with all the sensors and a dash 2. Here are some of the progress pictures: Here's a few shots from last night. Managed to do about 3 hours work which unfortunately doesn't look that much: Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 That's just the upper loom that goes behind the dash. I'm starting in the lower loom now: Here's a picture I took of a fresh and hacked engine bay loom: Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 Here's a few pictures of today's progress. The beginning of the engine bay loom: A few hours later with most the of wires traced and marked: Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 Looms are almost complete. Here's a sample shot: Finally I can see the light at the end of the tunnel. Here's the first of the completed looms. Just need to get a connect for the rear fog and reverse wires. Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 Spent about 8 hours on the engine loom. Here's a shot of the amount of wires after removing some of the tape: This is what the loom looked like once I removed the tape: A lot of the time today was tracing wires from the other looms as this is the final piece of the jigsaw. Here's a picture after I managed to mark up most of the connectors and remove some of the redundant cable for the auto box: I know the above doesn't look that impressive, but this gives you an idea of the amount of redundant wiring I removed from this loom: Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 Spent all last night and today working on the engine bay loom. Thought it was a good opportunity to relocate the fuse board Before: After, though I just need to conduit it and add the new alternator wiring: I've also been busy removing the drivers side fuse board. The idea is to run everything from the main fuse board. This has allowed me to remove some large cables. Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 Here's a picture of what the fuse board currently looks like: And one of the dash loom with the drivers side fuse board removed: Link to comment Share on other sites More sharing options...
Kev.O Posted May 4, 2013 Share Posted May 4, 2013 (edited) Well it's taken a lot longer than I first thought it would but I've finally finished the custom looms. In the end Mark and I decided to carry out a fuse box relocation as well as a fuse box deletion (drivers side). This involved a lot if rewiring and a little thinking outside the box but I got there. I'm really pleased with the results. It doesn't look much, but anyone that's tried wiring in the Supra will understand. I managed to wire everything right first time and only blew two fuses. First one was when I connected a test lead to the positive instead of the negative and the other was the 15amp fuse I used to protect the battery. This blew after I took the picture with everything on as I turned the reverse light on and over loaded the fuse. Here's some pictures: The test lab: The dash 2: The custom engine bay loom with only the necessary wiring left: Custom dash wiring (just need to wire the can bus for the dash 2): Edited May 4, 2013 by Kev.O (see edit history) Link to comment Share on other sites More sharing options...
Marco79 Posted May 4, 2013 Author Share Posted May 4, 2013 Thanks your a diamond I couldn't find the pics I had the pics give an idea of just how much work has gone into the looms! Link to comment Share on other sites More sharing options...
Marco79 Posted May 5, 2013 Author Share Posted May 5, 2013 (edited) Why can't I delete this dam post? Edited May 5, 2013 by Marco79 (see edit history) Link to comment Share on other sites More sharing options...
Marco79 Posted May 5, 2013 Author Share Posted May 5, 2013 Well 5th attempt at getting a finish I'm happy with and finally there Just the runners to do now Also made brackets to mount the fuse boxes and painted them today but will get pics when fitted Link to comment Share on other sites More sharing options...
nellie1966 Posted May 5, 2013 Share Posted May 5, 2013 No other word- WOW! Link to comment Share on other sites More sharing options...
Marco79 Posted May 10, 2013 Author Share Posted May 10, 2013 Couple of little bits done today Fitted sandwich plate and installed oil pressure and temp sensors Installed my new LED rear lights which I think look awesome will post more when I have a battery hooked up Link to comment Share on other sites More sharing options...
abtin90 Posted May 10, 2013 Share Posted May 10, 2013 Awesome build. Glad to see that your putting an NA engine to good use and using it to its full potential. Really looking forward to seeing this run. Will be following this closely. Link to comment Share on other sites More sharing options...
listy Posted May 10, 2013 Share Posted May 10, 2013 I'm guessing this ISN'T the one you're bringing tomorrow Marco Link to comment Share on other sites More sharing options...
Marco79 Posted May 10, 2013 Author Share Posted May 10, 2013 Awesome build. Glad to see that your putting an NA engine to good use and using it to its full potential. Really looking forward to seeing this run. Will be following this closely. Thanks mate the NA is far far underrated every bit I install I get that little bit more excited lol I'm guessing this ISN'T the one you're bringing tomorrow Marco Lmao why would u say that Link to comment Share on other sites More sharing options...
Kaan W Posted May 10, 2013 Share Posted May 10, 2013 Them custom looms look an easy job Some seriously good work going into this mate Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 10, 2013 Share Posted May 10, 2013 I would lose the 'devil toyota badge'!! would look a sexy arse without it. great work Marco! ill have some bling ready soon! oh shiney black Link to comment Share on other sites More sharing options...
Marco79 Posted May 10, 2013 Author Share Posted May 10, 2013 I would lose the 'devil toyota badge'!! would look a sexy arse without it. great work Marco! ill have some bling ready soon! oh shiney black Thanks mate I have thought about that but terrified of damaging the paint! Any tips? Good lad can't wait to see the results Link to comment Share on other sites More sharing options...
Guest aspire Posted May 11, 2013 Share Posted May 11, 2013 so thats where the LED rears went,,, superb!, you decided to keep the plenum black? thought we were going shiney.... must admit, looks spot on marco. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 11, 2013 Share Posted May 11, 2013 looking goooood Link to comment Share on other sites More sharing options...
Marco79 Posted May 11, 2013 Author Share Posted May 11, 2013 so thats where the LED rears went,,, superb!, you decided to keep the plenum black? thought we were going shiney.... must admit, looks spot on marco. It is shiney ....... Shiney black just the upper arms etc to get powder coated now Link to comment Share on other sites More sharing options...
Marco79 Posted May 12, 2013 Author Share Posted May 12, 2013 Bit of progress today removed stock knock sensors and installed the syvecs sensor, fabricated a bracket and mounted the FPR under the ffim to hide it and be in line for the return fuel line from the rail It's all apart and being painted now but very pleased with the result Installed a fuel pressure sensor on the FPR instead of the gauge for the syvecs to monitor Link to comment Share on other sites More sharing options...
Wez Posted May 12, 2013 Share Posted May 12, 2013 Nice build Link to comment Share on other sites More sharing options...
