How do you drive an auto with 3600 histall?
viper
Hi all,
odd question i know, iv always been manual and have just converted to auto for the drag strip.
iv just gone round the block and the car just kinda plodded along and made alot of noise, then when you put your foot down the revs rise a hell of a lot and the car doesnt realy move, i did let off.
Do the Torque converter just suddenly put the power down?
can anyone give me advice how to use it at the strip too? im sure i could work it out but im scared :(
any advice is much appreciated.
The revs will slip up to around 3500rpm. It will feel like a clutch slipping on a manual. Its fine though.
I had a 3800 hi stall and to be fair it drive me mental on the roads. Racing is a different story!!! :)
On a strip, brake boost up to 3500 revs until you feel the car about to break traction. Hold it there til light goes green and floor it ;)
ok, cool thanks for that mate, it felt pretty much like that, and i realy didnt like it.
im going to the strip on sunday if i get an answer to my other question regarding dieing at idle and an open port on the inlet manifold.
yeah, i bought the lot off of ROB from here, so the whole kit had been mapped to the injectors and turbo kit.
the only issue i have at the mo is it dieing at idle when warm.
plus i dont know what to do with this on the inlet manifold:
[ATTACH=CONFIG]167775[/ATTACH]
Dont want to teach grandmas to suck eggs and all that, but the map for one car/kit will not be the same as another. Do you have an AFR gauge or monitor to keep an eye on things? Where are you going on Sunday, shakey?
I eneded up having a lock-up switch fitted to mine to stop it slipping on motorway etc. Have a search on supraforums for decent lockup switch info
Also be very careful of gearbox temps they will rocket up. I had 2 SRD coolers to keep mine from melting!
its already been mapped.
it only felt slow because i was pottering around i didn't have the balls to open it all the way. i shall take it out tomorrow.
Where did you get it mapped mate, I have a mapecu and am not that far away from you and interested in who can map them?
Also, where are you racing on Sunday?
I bought everything from the same guy so the ecu has already been mapped for the set up.
i want to take it to TDI next time im down in essex as i have a friend who works there, to get it dyno'd and remapped.
Ill be at shakespeare sunday
OK, is it a pubic track day on Sunday? I had a look at the website and there is no mention of that, I was going to try to get to RWYB tomorrow at SP, but not had time to get the car ready, but could make Shakespear on Sunday if it was a public day?
RE the mapping, I hear what you are saying but there are so many variables I would be exceptionally cautious relying on the previous map. Fuel pressure, intake, exhaust, compression ratio, plug grade. Even if its only a narrow band to tell you if you are rich or lean I would be looking at the afr constantly.
cheers shane,
iv got a wideband in so ill be monitoring the AFR's tomorrow while testing.
yep its a public track this weekend.
let me know if you going down
OK will PM you if I can make it. Good luck and maybe see you there.
